Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
QuoteIn his report Coler also described the following simple, significant experiment:
"Given a solenoid consisting of two windings, one upon the other, of the same length and number of turns, enclosing a soft iron cylindrical core. Firmly attached to one end of the core is a pre-magnetized steel rod. If an alternating current is passed through one of these coils, acting as primary, the residual magnetism of the steel rod is strengthened during one half cycle, through the magnetism induced in the core, during the other half it is weakened. If now the other winding is connected in series with the pre-magnetized steel rod (as secondary coil) in such a way that the secondary current must pass through the magnet, one half cycle of the secondary current must be more or less subdued; in other words, a rectifying effect must be created. It may be remembered that according to measurement by Profs. Kloss and Schumann a high-frequency pulsed direct current ~ about 180 kc ~ is flowing in the output resistance of the apparatus, for the creation of which no other explanation is possible." Another experiment with two double-wound solenoids, connected in series, revealed that "in such a secondary circuit a considerable DC component exists which can be strengthened by means which we shall not go into here…" Experiments were conducted with the plate and flat coil unit to test their interactions: As the plates are not only charged as condensers, but also have directed currents passing through them it had to be assumed that their mutual influences not only consisted of a condenser effect, but that they also created a magnetic field… It appeared that the "Ankertrakte" AC or BD are not all to be considered as oscillating units, but that the single group systems, consisting of plate - to anchor coils - plate, already represent independent oscillation circuits. According to this the apparatus contained ten such oscillation circuits… In order to make the apparatus work the harmony of all oscillating circuits in their individual frequencies would evidently be necessary -- at least within certain limits determined by the suppression in question… The previous occasional success must be considered as due to chance. The mutual influence of the flat coils upon one another could not the other hand easily be examined because, despite the great distance between the windings (25 mm), they have remarkably great apparent resistance (about 200 ohms at 10 kc). It appeared that the power factor of both of the flat coils wound 1:1, in consequence of their peculiar interwinding have the astonishingly high value of 0.85. The value of the power factor was at a maximum at 10 kc, at which frequency the most favorable matching of the impedance… was obtained. The repeated mention of 10 kc is also found in the scientific literature on the Barkhausen Effect. After all his experiments and measurements, Coler offered the following explanation of the way in which the apparatus works:
"Due to the connecting of the batteries, a current impulse is induced in the anchor circuit which charges the plates. The discharge circuit from the plates causes electrical interruption of short duration of the battery current in the field circuit, which furthermore inductively interrupts, or changes the direction of, the battery current in the directing current for a short time. The electromagnetic field induced by this process in the directing circuit by its dissipation, induces over the field circuit a current in the anchor circuit recharging the plates, and so forth.
"Due to the influence of the Barkhausen Effect each single process has an impulse-like character, and the necessary change of phase is produced to allow the regularity of the process.
"Due to a source, up to the present not investigated, and not explainable by existing scientific theories, an additional quantity of energy is freed during each cycle which leads to a continual raising of the amplitude of the mutual processes, until the magnetic cores are saturated.
"From the fact that in the resistance of the apparatus pulsed direct current is flowing… There is possibly an up to now unknown rectifying effect, or alternatively the gain in energy is produced only during one half of the cycle, either during the charging or discharging of the plates. The activity in the apparatus must take place in the ten oscillation circuits in a phase-like manner… No technical means were available to make the necessary tuning adjustments.
"It is clear from the above that the success of the inventor up to now could only be due to chance, or happy accident. The necessity, therefore, arises to transfer the apparatus from the state of empirical development, with sufficient technical means and based on results of an exact basic research, to a state of working procedure which can be controlled." Other experiments, conducted by Frohlich with the arrangement in Figure 6, convinced Coler that his theory was correct:
"The result obtained with this experimental arrangement… was the clear proof of a considerably larger energy during opening (intake), compared with closing impulses. The [10-50%] difference is always in favor of the opening impulse… Consequently this observation can also be considered as a proof of the fact that an energy difference exists. [There is a] considerable, but extremely short, energy peak of the opening impulse. My development of the "Space Energy Receiver" was based on this and was successful."
In the 1980s, George Hathaway (Planetary Association for Clean Energy, PACE) constructed a Magnetstromapparat that produced 50 millivolts, and demonstrated it at unconventional technology conferences. There has been no news of further development. The Barkhausen Effect upon which the Coler inventions work is a low-field phenomenon that occurs when a ferromagnetic material is subjected to a change in the applied magnetic field. A series of discontinuous steps develop, corresponding to reversals in magnetization domain volumes from 10-10 to 10-8 cm3. The size of the discontinuities can be increased by stressing the magnet. Possibly the soft iron magnets which Coler used were subjected to such stress by ultrasonic magnetostriction from the coil windings at the 180 kHz resonant frequency. One can only wonder why British Intelligence (sic) declassified the Coler report, but we can be glad they did. If only they had seen fit to include more schematics of the Stromzeuger, because the available diagrams are woefully inadequate. At least we now know a few key facts, to wit: (1) Ferromagnetism resonates at 180 Khz; (2) The Barkhausen Effect can be amplified to provide useful power (10 Khz is another key frequency here); (3) "Some of the magnets are wound in a clockwise direction looking at the N pole (called left) and others in an anti-clockwise direction (called right)". The resistance of the magnet-coil combination was about 0.33 ohm; (4) "The basic principle is that an electron is to be regarded not only as a negatively charged particle but also as a South magnetic pole"; (5) "The novel feature is that the capacities are connected to the secondary core through permanent magnets"; (6) "There is a considerable, but extremely short, energy peak of the opening impulse". It is to be hoped that the Stromzeuger can be redeveloped, since it is a relatively simple, low technology device requiring no exotic components. It should not be left "to chance, or a happy accident", as it was for Hans Coler.
giantkiller
forest
Quote from: giantkiller on March 31, 2010, 02:31:17 PM
Amazing...
The guy that is credited with giving us the light bulb actually plunged us into darkness.
Who knows, maybe he was innocent ?  He left nice notes  ::)
giantkiller
True.
Edison could have been a pawn. After all he spent hours at the tasks while the financiers were comfortably watchful.
Quote from: forest on March 31, 2010, 02:58:27 PM
sparks
   2.5 years ago I did this.  Grumpy and BEP told me not to do it again if I didnt want to end up typing using a pencil in my mouth.
   I did alot of work with ozone cells in water repurification and seen my share of coronal discharge but it was to an obvious ground.  This is the only time I have seen an open air discharge to nowhere.  I have seen plasma created like you are after when a pole pig shorted from primary to secondary and sent 20k into a building bridging the fused disconnect with about a 5inch gap.  Again there was an obvious potential setup between the grid and ground.  The current was resisted just enough to allow the primary pole breaker to stay engaged.  Then there was the time some water with salt in it sprayed a 460volt motor relay box.  I heard the hiss but was trying to minimize damage control like stop the water from spraying all over the control room.  Well the plant called for the motor to engage and so it did.  It blew the NEMA 1 enclosure cover right off the box across the room and by my head at a good 100 miles an hour.  Only thing I can figure out is that the hiss was producing hydrogen gas of some sort and the plasma from the contacts making ignited it.  The motor starter itself was fine.  The box not so good.  A little bloated.  Well on the day in question with the flyback pulsing the iron coil I was curious enough to insulate myself from ground and stick my paw a good 12 inches from the weird dually plasma things.  Cold ass ion wind heading from the ground to the coil.  You could cup your hand and feel the cold stuff fill up your palm then leak out around the edges.  That and not all of it was coming from the air I could feel it coming from out of my hand.  It is not the feeling you get when you radiate your body heat and cold is radiating in.  It was cold radiating out.  Weird as it gets.  Pretty dumb too but I lacked any kind of thermal sensing device and just had a gut feeling this was not your ordinary radiant em event.  I think this is what was happening but not so sure.  The coil was acting as a solenoid and providing a relatively permanent magnetic field of a torroidal nature.  The lead from the flyback was attached in the middle of the 6 turn iron coil so the current was creating like two solenoids  back to back.  The pulsed  electric field was causing ionization of the air on the ends of the iron coil and the current maintaining the split polarity solenoidal magnetic field lines.  The free electrons liberated from the air ionization started a current that followed the magnetic field lines from the iron coil.  Since the coil ends extended through a uhmw block and ions like to float they were accruing inside the electron current flowing along the magfield lines.  This kept on going until with the ions relatively cold but still very positive but lighter than air amassed inside the electron loop.  This positive pole was insulated like a low pressure area in a twister.  For any high pressure to get to it it would have to negotiate the hot electron circulation.  The cold feeling was the thermal energy drop of the mass of the air and my hand as electrons left the atoms heading for the little cyclone deal I had going.  Ions lack the thermal energy of the relatively hot electrons.  I am quite certain that if I had kept running this thing it was going to get cold enough to form condensation of water vapor and some eery fog as reported around other plasma devices running in open air.  I didnt need to wait around for that kinda shit to happen and pulled the plug.
166.204.44.125
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
