Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
Really, I mean really ingenious!
Nice design. In my experiments I noticed there are only four positions, visually. The smallest being matched to the gap inside the stun gun. The outside gap is merely for adequate production to go through clothes and flesh to hit the nerves. Short the mini gap inside and you got nada. That inside gap is quite small and not that specific although it is written up as to be. I have found different. You got to hit a small coil? You use small gap. You gotta hit a big coil to jump an inch? Use a big gap. Where the gap is important is the coil you want to hit. Fat copper coil will absorb all the energy and you get nada. In other words the gap size matches the inductance. The energy has to be greater than the coil. Obviously. What Tesla's patents don't show are the increasingly graduated stages. Motor brushes, the commutators act as the initial small gap. Then we get bigger and bigger. If you don't want to strive for exact resonance for massive reactance in, let's say, 2 stages then play sloppy and just keep throwing step ups in the circuit. Thats right, Ad infinitum! I have done 10 stages of 1:1 rat shack coils and the output still flies undiminished. Oh what fun! Like ringing the bells in sequence. The coils just are hyper reactive to high speed potential. If you want to use step ups then you need the loop of a cap and an added gap. Quite noisy. 8)
I appreciate the detail on the gap size and would really like to see any results where the gap size is specific to the geometry of the next stage. I am sure that the match can be made very specific. A matched gap to a very High 'Q' resonance ringing should really produce very expressive output.
So here is one that I am sure Grumpy had covered but can't remember. When the discharge crosses the gap the generated magnetic field should be spherical albeit very noisy or have an erratic edge and travel with the discharge from terminal to terminal. Not that it means anything here but should be like a cannon ball when it hits the other terminal. Just thinking about all this in a different plane of effect.
The small nst needs a small gap. Yes! And if you use a stun gun you can copy the 1" gap throughout the stages.
Tesla used commutators as diodes, resonance to increase the bias. We use diodes. Resonance is an option depending on the power out needed. Don Smith PVC is the Tesla ozone generator minus the fan / motor. The NST is the motor.
giantkiller
Received (4) 30kv 510pf capacitors through Ebay.
giantkiller
giantkiller
giantkiller
In relation to Meyer:
He harvested the energy at the point of the crack. ZPE.
If you store the gases then burn them later you have lost the potential.
The crack can be produced in many ways. All those ways are in this site, Overunity.com. When the potential that has produced the separation has subsided then we harvest the returning backlash. This return is the atomic reconnection or rebonding. Mother nature abhors a vacuum.
Based upon the spectrum range we exist in this controls the atomic bonding in a limited fashion. Naturally occurring bonds exist all around us, obviously, which produce familiar examples of matter. We have the knowledge to break those bonds in numerous ways, i.e. Cleaning, cooking, burning, exploding, cutting, moving. This is where to resonant swing comes into play. We push, we wait, we harvest, push, wait, harvest. Your goal is to find the timing depending on what materials or forces you use. Using resonance overcomes the losses. Work with nature and you rule the universe. As a child did you ever cause tidal forces in the tub with your little hands? You don't have to stop no matter what age you are.
Look at your failed attempts in the past, change your timing and viola'!
If you want to use sines waves then resonance is mandatory. Square waves afford the speed inherently because of the rise and fall times.
--giantkiller.
