Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
otto
Hello all,
@NickZ
I was on a very nice 3 weeks vacation and it was raining 2 weeks so I had more then enough time to work on my TPU and I have blown a lot of ICs, transistors and have learned a lot.
hmmm....yes, SM didnt use a function generator (FG) like a ICL 8038 or a XR 2206..... but he used oscillators, thats clear.
I dont know if the sound could be analyzed with a scope. Im using my little radio for that. At some frequency mixes I can hear a very strong 5kHz signal with my radio when I pulse my TPU and thats good enough for me. At other frequency mixes I can hear whats going on in my coils and on the scope I can analyze such signals. Maybe you will ask whats to analyze because we have "only" kicks. My answer is that we have kicks but not oridinary kicks. I mentioned it already.
I have a lot of magnets, used them in a lot of ways near the coils, inside the coils.... but as I can see there is no need for them. Of course there are cases when magnets are very usefull but I dont want to discuss it. I also used a lot of various caps connected in all possible ways in my TPU and hmmm.....they are maybe needed, not so sure.
Otto
NickZ
  @Otto & all:
   Thank you so much for your reply.  Yes, the same two weeks of very stormy rainy weather here in Costa Rica, also a 6.8 earthquake right in my area, and the volcanos were and still are active.  250 houses and hotels located on the beaches just north of me are ruined and 35 or more electric power posts were also downed from the 65 mph winds. And, no electric power for me for a while, no water also.   But,  since the weather is somewhat back to normal, for now, I can continue to work on my coils and power generating systems.  Glad to hear your vacation only had rainy weather.
   I see no point (for me) to use power supplys, function generator, etz... as when at night all power is out... I can't even find their plugs. This weather I take as just a warning to give us time get my electric power source project going. So that I can have my water pump and well giving me water, and am also able to use my electric range to cook on, electric hot water heater, Ac, etz...  My point is that I take all of this very seriously.
   Thanks again for taking the time to answer me.
   Good luck to all with your work. I will continue to keep an eye on what is happening, from here.
  If I can help in any way, please let me know.
  My appologies to GK and Wattsup if I have offended them in any way, as they are both my most valued and honored co-workers in this team effort, even if they will not reply, at times. Hopefully, they will see where I'm comming from.
        NickZ
  PS. From the "sweet spot" of CR. (Picture below)
giantkiller
I see no offense here. Everybody is welcome.
Nice pic. I like the lava flow to the water in front there.
This just in:
Do not get your wire from radio shack!
Due to rising retail costs and employment costs the corp has had to shop most visiously which harms us.
I used to be able to get tinned coated wire there, like back in SM's days. I called a wire supply company and asked about the tin coating. He stated that the cheap wire does not have this and that the copper purity is low. I had just gone to radio shack and pulled insulation back on a number of rolls and saw no tin. Well that made my mind up. Low purity equals lack of resonance qualities.
The better wire is on its way.
My quietness is due to fact finding and pattern matching. I spend huge amounts of time pondering. Tesla's orders.
I posted this to Wattsup.
Look at this this way. As the first field collapses we want to enable that or push it down faster. Get your timing just right and you see the bigger secondary spike. Push the swing at the point of least effort. Now if you have a ring of smaller diameter inside a ring of larger diameter at the correct ratio and on the same horizontal plane then 1 pulse will do the trick. StClair mentions this ratio of inner ring is 1/3 diameter of outer ring. We have 2 fields. If there are 2 rings of equal diameter and stacked vertically then you need to pulse sources. Else with 1 pulse source the ratios of diameter to stack height have to be exact mechanically. We can use switching speed to act like a spark gap discharge.
NickZ
  Gk and all:
   Thank you for your reply. Glad you liked the picture,  it is where I live and do my some of my ponderings, then later visualize the following designs mostly at night.
   Since I can only assume the 0 external input to the SM toroid coils can come only from previously charged caps, and that without them along with the magnets, there would be no initial kick. I may use that same method to fire my version of the St.Clair wormhole vortex generator design which I will presently begin to build.
   I have been thinking on how to make both inner and outer cores of non laminated iron. As I can't come up with just how to make them  using laminated core materials. So for now, I have decided to make both cores from a 3" high 1/4 " thick solid metal soft iron strip, formed round and welded together at the ends. That will produce a 15" diameter circular iron core, and the same for the 1/3  diameter (5") inner core.  I will use a Single wire of solid copper insulated home instalation cable, to wrap both cores. And plan to pulse the coils with a single frequency HV source using a 12 volt motorcycle or car battery and ingition coil set up that will produce 20.000 volt pulses.
  Once I make the finished coils I will upload a picture of it, and discuss the method of getting that pulse circuit functioning.  That is where you or any others can possibly help me out.
There is a detail in the St.Clair's coil wrapping design that shows a 45 degree offset on only the outter wire wrap of the coil, but not on the inside. I think that this could be an important consideration in getting the vortex spinning on both coils,  in opposite directions.
I will use a single HV frequency pulse to cause the opening of wormhole,  or vortex as I prefer to think of it, and to maintaining it open, thus drawing in Aether to the coils and further storing it into a cap, and from there to a rectifier, and out to the load.
How does that sound to you all?  Any ideas are most welcome.
  It is 12.00 am and I'm going to bed, hope I can sleep as my imagination is going wild...
                                         NickZ
giantkiller
@nickz,
Agentgates made coils using specific angles. These are a light subset of the rodin coil. The StClair patent also shows this type of topology configuration.
Adjunct:
http://mathworld.wolfram.com/Topology.html
My take on the StClair is the wind gapping. This is of pertainent interest and what he mentions about this.
