Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
NickZ
    2 All:
           A not so current build.
  But, could have more than one answer to our power puzzle, if we could just ask him.
  Code:  Beward of strangers bearing false gifts...
giantkiller
I was going to try to use the formation animator program from www.formationresearch.com to show 3d field displays and interaction. It looks to be a really cool program. But alas, I purchased it and it crashes on my pc. I have the current directx version too. I have tried numerous times to get in touch with the company to no avail.
If anybody has a clue let me know. Cannot a man be without correct tools (Yoda paraphrase). :(
I am currently reading 'The Gift' by Doug Ruby. I am going to try to get in touch with him also. And anybody associated with Lucy Pringle.
I am working on a virtual spark gap circuit at the moment based on cmos switching window circuits of Earl and Otto. Parts are coming in. Ebay is great. You gotta love the autolinks on this site. No links to Overuntiy type words or phrases only commerce based entities. Isn't money the root of all evil? So I have heard.
The use of flip-flop outputs as clocks leads to timing skew between the count data bits. This skew window is faster in cmos.
Add another hero to the list: Leonhard Euler
--Creativity = tools + knowledge. Plus wisdom = success.
This next quote is why the jitter on a 555 gets focus:
QuoteHello all,
guys,
that we understand us corectly:I dont say that a 555 is a must but as I see its a good IC to get square waves.
The main point is in the MOSFET DRIVER that is connected to the output of such a 555. Or another IC that can give the square waves.
Hmmmm....hard to describe.....we need signals in our coils that are in 1 moment positive and in the next they are negative. Kicks of course. The positive and negative kicks not in the same time.
I was totally desperate and connected a 4007 IC to the 555. The 4007 has 3 pairs of PNP/NPN MOSFETs inside. Of course this was not working but I saw fantastic signals.
And I forgot to mention:
with 2 frequencies I see 3 sorts of kicks:
1. very fast perfect kicks fast ON/OFF times
totally useless to get even 1W of power on a bulb. See,Im talking about power.
2. kicks with a very fast ON time but the OFF showes a square wave
also totally useless when we talk about power on a bulb.
3. kicks that look like hmmm.....they are in a tornado. They are not straight like normal kicks. They are a little bit ....never seen this but I know what they are. Notto mention how such kicks sounds on my radio. Scary. Somehow I have the impression that they are "gliding" on ice. Never mind.
This kicks are also useless wehn we talk about power on a bulb.
Now you maybe wonder what Im wrighting.
The point is that not 1 of the frequencies when used seperatly will give any output power from my TPU.
But when I use 2 frequencies I have a full light. Yes, the current is high, maybe 2A at 24V but it doesnt matter how much current is used.
Forgot to say: Im measuring with my scope 250VDC. I made such controls because I dont see a need for a high voltage in my coils.Im talking about a ECD TPU.
@forest
look inside this generator and look whats the output. Oridinary transistors I suppose. Thats NOT good enough.
Otto
NickZ
   GK & Otto:
    Probably have to wait until the formation animator site is up and running, it's interesting though, hope you get it to work.
  What did you think of the Grey holding the Mayan code?  It has been decoded.
  Check the Mayan Calender picture below.
  There have been lots of Crop Circle references to energy forms. Maybe hundreds. They are trying to tell us something, before its too late, but, we may be a bit slow and dense for them.
   @ Otto
   I was wondering if you had gotten your parts from Germany,  you must be having great fun with them, as we haven't heard back from you in a while, again.  I for one would like to hear of any more news you have to tell. Your last video was good and informative, and such a nice looking guy, should really make some more videos.
                                                        Nick
giantkiller
accumulating notes...
Why not use floating ground as feedback loop? Just like blowing an amp on stage.
otto
Hello all,
@NickZ
Im still waiting for the parts from Germany but this is not the problem.
The main problem now is that a tinned wire works a little bit different then a oridinary copper wire. In a copper wire we are mixing 3 frequencies, they work together or dont......everything is well known.
But the tinned wire is something totally different: in 1 moment you have no light and suddenly you got one or you change a frequency and suddenly I see totally different signals or......a lot to describe.
As already mentioned, it seems that at 1 frequency, 245kHz, the particles are moving on the outside of this tinned wire, at the other frequency, 35kHz, the particles are maybe on the CuO2 layer that is between the copper and tin and at another frequency the lowest, are the particles only in the copper circling around the circumference of the TPU.
Of course there are different resistances of the metals and so is the speed of the particles different. Of course, as we use 3 different frequencies we already have different speeds of the particles but ....as mentioned, in my case I see at some frequencies totalls different signals.
But the best signals I see when I disconnect the minus or plus from the coils and mosfets and when I switch the Volts on my scope to the range of 50mV. Amazing signals.
Otto
