Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
0 Members and 18 Guests are viewing this topic.
NickZ
  @ e2:
      It may have been Bruce that came up with the three frequencies, but nobody has been able to make them work, as far as I know. Even when winding the three windings in the TPU like Bruce recommended,    if he had any success from those coils designs and frequencies,  I must of missed it.
                                                   NZ
NickZ
  @ All:
     Since the 3 mentioned frequencies are dependent on a particular tank circuit, I would think that they may only apply to a particular device like the 15" SM coil. But there may be a certain vibration that is universal and can be used to cause resonance in general. Maybe some vibration that jibes with the Aether flow, and will cause an induction in the coils and cause them to act as a superconductor.  Hopefully Otto will have some luck with that.
  It is obvious that the scope and other test instrument including the persons body and his thought waves become part of the circuit.
Keely mentions something about mind technologies influencing his work.
  I also don't get what is the proof of concept yet.
  It does seam that SM had different coil materials that worked. Not just tinned copper, as he also use bailing wire etz... which does oxidize, but is not an aloy, just rusty soft iron.
  While copper is not magnetic, it but must have other qualities that make it act as if were magnetic and will cause a Lens effect similar to iron, when hooked up to a battery or a cap.
  I still tend to side with the Vortex theory and continue to look for solid state non moving devices that will go along with that view point, as I don't know what a superconductor really is. Although from reading about it, it looks like it works with the influence of vortexes to produce a charge. Did SM know what it was?  Does it really matter? No, if we can make it work. We don't even know what electricity really is...
otto
Hello all,
@NickZ
I dont want to talk about frequencies because I think every TPU will work with his frequencies. It depends on the wire lenghts. If the TPU works only with the mentioned frequencies then OK, I have no problems with them. So far, I dont see any "effect" but as I still have to wait for the parts I dont wonder that I dont see anything.
Every frequency is feeded into 1 coil and the result is a "mix" of 3 frequencies.
Yes, Im now hmmmm.......using my Aluminium ring with I dont know how many turns of a thick copper wire as a "pick up" coil. It was @wattsup who gave me the dimensions. I hope he was it! This is maybe the same silver ring as we can see it inside the 15" TPU or on top of a 6" TPU.
This pick up coil is NOT pulsed but I see fine signals. When I then connect a + to this coil I see the best kicks ever seen at all frequencies and the current from my battery is still 1 - 5mA. But to see all this  I have to place the potentiometer, wich is changing the frequency of my oscillator, in the middle of this ring.
Now, if the signals are amplified......the you can see them in volts and not anymore in milivolts.
Of course, if I use a oxidized copper core the signals are much bigger then without a core. I dont know the exact wire sizes but the controls are thin wires and the collectors are 1,5mm2.
I really dont know it this is related to a TPU but.....Im playing a little bit and learning. Maybre for some tests in the future because I still think that a core is inside each TPU. This is out of question for me. I only have to figure out the best metals for a core.
There is no need for a photo because there are a lot of photos here in this forum.
Of course Im working on this TPU problem and I see not 1 reason to stop.
Otto
giantkiller
Let me throw this pattern in the mix:
The GK4 was very noisy and even more so when the certain frequencies were achieved. This is not to say that I needed a correct set. With the magnetized core getting beat with an immense amount of eclipsing the thing just spewed. So it looks like the Bedini field shearing but in a chaotic Rodin type pattern surrounding the device itself.
Now it gets real bizarre. There is a Rodin pattern surrounding twin galaxies 'in the dance'. I mention this because of the perect symmetry going on. It is shown in the youtube: 'Through the wormhole' series. I was surprised at the terms usage that closely suround what we are working on here.
So what I see are the entry points being very specific by most involved here. Otto and a few others have tried a jumbled mix at one time or another.
In my own attempts I have played both sides of specifics and chaos. Either Nickz or E2matrix posted documents that mentioned floating grounds and that is most important factor based upon the writers credentials. This has popped up from obscurity every so often and not from the device builders either. Tesla stated 'multiple indepedent floating grounds' in his 'Nonlinear oscillating shuttle circuit'. Maybe SM started with one in his simple beginning devices.
My latest thinking is that a floating ground of a magnetized ring enables the device potential to remain high due to the magnetic activity looking like storage. This would act as a medium for the capture or slowing down of the high speed energy. Also fits in with the virtual aperture of previous posts. Mentioned a few times has been the magnetic toroidal field acting as a mag amp.
penno64
@all
I was searching youtube for TPU replications and came across this comment posted
to -
TPU V1.0 Experiments (Part 1)
JackDurban
2 years ago I worked with Steven Mark. The magnet was a ruse. It closed a reed switch in the primary. Steven thought it would throw off analysis of snooping eyes during demos. He was the most paranoid person I ever met. By the way, if you want a little hint as to the device's basic make up and why it acted like a gyro in its resistance to motion pull Tesla's patent 381,970 circa 1888. Study the quadrature nature of the coils and disregard the rest. From there ask yourself why the specific resonant freq.
JackDurban 2 years ago see all
Video Responses"
Regards, Penno
