Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
NickZ
    2 All:
    Could it be that a disconnected negative, or an open ground allows for the circuit to then become an Open circuit? And can therefore draw in or least not restrict or limit the available energy that is then available to flow through, or be produced by the coils, through an otherwise closed and limited circuit.  Looks like when you disconnect a ground connection is like opening a RC current Aether valve.
  In order for any unit to output unending energy, it has to be able to redirect or draw through the device that same amount of energy, just like a photovoltaic cell.  Any closed system will not allow for that.
  We still need a working unit that can be used as a Prototype, or as an example to work with and improve upon. Like is being done now in the JT thread, using their basic JT as a starting point.
  Question is, do we have such a device, yet???
e2matrix
Quote from: penno64 on July 12, 2010, 04:50:32 PM
@all
I was searching youtube for TPU replications and came across this comment posted
to -
TPU V1.0 Experiments (Part 1)
JackDurban
2 years ago I worked with Steven Mark. The magnet was a ruse. It closed a reed switch in the primary. Steven thought it would throw off analysis of snooping eyes during demos. He was the most paranoid person I ever met. By the way, if you want a little hint as to the device's basic make up and why it acted like a gyro in its resistance to motion pull Tesla's patent 381,970 circa 1888. Study the quadrature nature of the coils and disregard the rest. From there ask yourself why the specific resonant freq.
JackDurban 2 years ago see all
Video Responses"
Regards, Penno
Good reminder on Tesla's patent.  It always boggles me how similar this looks to SM's big TPU and knowing SM studied Tesla a lot.....
sparks
Quote from: e2matrix on July 13, 2010, 01:33:26 AM
Good reminder on Tesla's patent.  It always boggles me how similar this is to SM's big TPU and knowing SM studied Tesla a lot.....
When a coil induces a counteremf it must first disrupt the magnetic field in which it lies.  As it does the coil sees a changing magnetic field and generates the counteremf and we say the signal is choked.  We do not see any loop current because of this.  This would be Tesla's coil of highself induction.  Within the confines of his coil of high self induction is usually found a coil of low selfinduction experiencing the same magnetic field disruption as initiated by the choked input.  I'ts counteremf is more in tune with the initial signal impedance.  In an ac voltage transmission line the selfinduction along the transmission line results in tremendous amounts of power being lost.  Tesla recognized this and told Westinghouse he had a better transformer that would use pulsed dc on the transmission line.  He even made the motionless dynamo's to do it.  Even patented them.  The power companies now use pulsed dc transmission on their main trunk lines to overcome the selfinduction losses in transmitting ac.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
bolt
@all
to -
JackDurban
Video Responses"
Regards, Penno
Magnet not a ruse you can be quite sure of that.  The magnet squashed the hysteresis of the mag amp which consists of 2 small toroidal ferrite cores it can be done with one with less efficiency. All later models used 2 ferrite rings with a magnet close by. The mag amp changed the inductance of the large coils to keep them pumped into a high VARS condition where the VSWR  = ~
This allows low cost simple parts of the late 1980's like 555's or 74 series logic to control the mag amps.
Reason is very important and SM already told you this. The high volts and amps swirling around his coils would have killed most early FET's and  trannies of the 80's. Even today an IGBT of 3kv and 50 amps handling going to cost like 50-100 bucks.
Mag amps provide control over very high volts and amps without problems of them being destroyed. In the large TPU my guess to provide an o/p of 1000 watts requires 20 KVARS on his coils. The magnetic field will easy be enough to interact with earth magnetic field and create juddering.
The frequencies in the TPU are related to the the size. SM already told you this there are NO magic frequencies. The ONLY frequency of common use in SM tpu is 5khz which is a standard clock he just happened to use. It may have been part of another device or circuit as SM was fond of using other stuff he had laying around.
This is used as a Quencher at 5khz which interrupts the oscillations on the TPU which increases the overall Q as in Super Regen radio. If you do this the o/p will contain the source you want ie DC power out PLUS 5khz sat on top and this is EXACTLY what the TPU provided. This is why SM said his device operates a bit like a radio collecting signals. ..and it does.
The effect of the TPU is a precursor as SM said its a means to an end and the frequencies going around the coils are just that and nothing more - means to an end and are not the part you seek.
All OU devices i seen on paper at least have similar principles. Disturbance of the ambience's does not alway mean coil banging.
The TPU is nothing more then a 3 phase pump to create an excess of 20 KVARS this WILL take several seconds to wind up like a turbine AND interact with earth magnetic field but the earth field is NOT the source of the energy.
The TPU is a virtual electron. As creation of a giant electron spin field we create fractal copies into ambient electrons spin fields. Electron themselves are NOT electricity they are a parasite going for the ride.
I give you a quote from my mentor
"RE (RF) current node within COIL (amps max voltage zero),
OU in nature as it pumps energy from electron spin domain,were energy in +
energy acquired / energy in = overunity = energy out .
as field collapses its transfered to a charge within a tuned LC
as joule ampere volt farad potential. (diode plug )
tuned LC capacitor can act as shorted coil equivalent at hi Q." - Hector ARK Research.
I can create and demonstrate a 3 phase pump using 24 volts 10mA and the o/p is over 2000 VARS! If i add quenching i can increase the gain and get 20,000 VARS the i/p power required is milliwatts.
sparks
  Many years ago I was called out to repair a heating system behind another technician who had installed a second control system transformer and left the old one active.  Both transformer secondaries were toast.  The primaries fine.  The electronics on both boards was fine the wiring in between the two boards was melted.  Large amounts of current had circulated between the two transformers with no consequences external to this circulation.  One transformer secondary alternately seeing the other transformer secondary as a load.  The homeowner wanted to know why a fuse hadnt cooked.  I replied that the transformers were impedance protected where the wire is so fine that it acts as a fuse.  Which is the case for the primary windings in these step down transformers.  Well it didnt work this time did it she replied.  Always rembered that job out of thousands.
Think Legacy
Spread the Love
