Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
The video has an enormous amount of validating demos of graphics models I posted over 3 years ago.
Are you talking about the crystal radio demo as the Tesla coil?
Also:
This site:
http://www.zoklet.net/totse/en/fringe/gravity_anti_gravity/scalar1.html
Looking for references to the publications of EXTRAORDINARY SIENCE, VOL II, ISSUE 1.
If anybody knows where these are It would greatly appreciated. I need the graphics.
Quote from: Loner on July 16, 2010, 04:02:48 PM
GK, That is nice....
Did anyone else notice the "Editor's insert" that showed a Tesla Coil driven by the Mag amp concept.  That coil had NO POWER INPUT, just the control.
If that were truly operable, as shown, then the game is over.  I can't wait to see as I'm going to wind up a basic immeadiately, just to see.
sparks
    The tesla coil mentioned appears to be in receive mode.  The circle is a symbol for a capacitor.  Just one electrode plate piece of foil or metal stick way up high.  The inductor is an inductor that induces an electral motive force.  The ground is the other plate piece of foil or metal stick placed way down in the ground.  If an electrostatic charge is conveyed to the stick in the air it becomes charged relavent to ground.  An electric field now persists just like you are inside a charged capacitor.  Inside the capacitor is placed the helix which will respond to an electrical current as one would find flowing between plates of a  capacitor.  There is no conveyance of any electrons between plates of a charged capacitor but there is an electrical field.  If between plates of a charged capacitor we insert charged mass then a force, the electricity,  goes to work on mass and it moves.  The velocity of the mass an indication of the amount of energy transferred from the electrical field within the capacitor.  Assume that we are inside the capacitor and move one end of a wire close to one plate.  The end of the wire will now be in the electrical current flow between plates and charged mass free to move inside the wire will move.  It will move without us having to short the capacitor.  It will move not in a linear relationship to our movement it will move in an expotential relationship to the wires movement.  The closer we get to a plate the force on the charged mass increases expotentially,  We do not have to move the wire against the electrical current.  If you have a river flowing by you to get some power out of the river all you need to do is put a paddle in it and hold on.  It will spin you around until the paddle is out of the flow.  Reinsert the paddle which will take some work but no where near the work exhibited by your transformation into a turbine.  Notice that the river could give a damn if it is spinning you around like a top it is going to flow no matter if the paddle is in there or not.  The Earth is charged up to a full columb or more.  This is an enourmous amount of charge.  Charge comes from the flow of virtual particles which create all the known forces.  We are walking around on a charged spherical capacitor where there is a tremendous flow of virtual particles to support the Earth charge.  Out there in space a few Earth radii away all around the Earth there exists a difference in charge state whereby an insulated conductor would experience a 36kv emf.
w
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
@Bolt,
To save time could you post or send the 3 phase motor script you have here?
Tnx in advance.
Quote from: bolt on July 14, 2010, 10:52:52 AM
You need open source VLC player to watch this file as its open source OGV codec for any platform.
https://sites.google.com/site/silverfreeenergy/links/out-2.ogv?attredirects=0&d=1
This is for self sync RV 3 phase motor runs mostly on Radiant Energy just replace motor with the 3 collector winding of TPU and it will run with gain! The frequency is not important for TPU it will run at any frequency so desired. I suggest though an 12 inch tpu made of 4 turn collector with 0.01 tank cap (SM large yellow caps HV 2000v) will put the TPU in the 100kHz region.
You create VARS your create SCALER WAVES! RE =RF where RE enters at node points.
If you want replace the fet with mag amp same at SM did and bias with a magnet.
I have omitted the 5khz quenching circuit as it overloaded the sim and i couldn't record it but increases gain about another 100 fold.
bolt
Quote from: giantkiller on July 17, 2010, 01:04:02 PM
@Bolt,
Tnx in advance.
Sorry GK i dont have any script for this now i make these circuits get the results i expect to see on the simulator then tear them down. On this occasion i happened to make a screen-shot movie for someone else so i thought i share it here.
Where of course a simulator can only show conventional circuit and logic then the road to OU starts with precursor technology which is standard text book RF. No magic here. I only need to create the conditions and nature will do the rest. Not everything can be validated on a sim but an awful lot can be. An oscillator is an oscillator and phase and timings are good enough for real life replications.
Once its understood that RE = RF then it easy to understand how joule thief works or Katcher or Dr Stiffler amplifier or hundred other devices because they all speak the same language only the method changes.
As i said a magamp is just a useful device and not required to make a TPU its just another method of controlling the phases without using silicon.
People ask to see some useful stuff. I give a circuit one simple power fet and handful or caps and resistors and to use a standard off the shelf 3 phase motor can run on 48 volts and virtually zero current. Its FAR more useful and powerful then any Bedini motor or imoteep fan but no one can be arsed to try it. Only when you build something like this you become shell shocked and in awe of how there can be many amps and few hundred volts in the motor in circulation. The magnetic intensity is amazing far better then a Newman motor.
Every-time i see a special "super duper" magnet motor I RUN!  Why? Because to replicate such a motor will cost many many thousands of dollars or it requires IPO funding of $10 MIO and up so they ALL become paper weights or museum pieces.
If you cant make 99% efficient or OU device with cheap off the shelf parts without using Kryptonite or Searl rolled magnets at $1 MIO each then don't bother:)
NickZ
  @ GK and All:
    Lead-out energy:
    "It is extremely important to realize that resonance hunting is still very much an art.  The Output Instantaneous Power can show a COP >> 10.  When the circuit is disassembled and reassembled with the same electronic components, the COP can drop to 3.  It appeared that the clips used might change the frequency considerably.  This is in line with our understanding of resonance â€" a few hertz to either side of the resonance condition will show sharp decline in amplitude".
"Now the secret is out.  Any research organization can buy two oscilloscopes; produce a two layer toroid; use the inner layer as Joule Thief to act as Primary.  The outer layer acts as the Secondary of a transformer and an LCR circuit can be placed for tuning.  At the appropriate settings, the COP can be much higher than 1.  In a more advanced form, the battery can be replaced by a signal generator.  Resonance Hunting via a full frequency sweep can take place.  Once the correct frequency is found, a cheap oscillator circuit can replace the signal generator".
"The actual size of the toroid, the core material, the exact electronic component parts can change.  Resonant condition with COP > 1 can still be achieved.  The “race” is to get the best configuration to lead-out most electron motion energy for actual products.  Every team known to me told me that they would keep such information confidential as such information is worth many millions or billions".
   GK:  Is this not what we were trying to do?  Giant JT- TPU?
   Proof is in the pudding...
                                           NickZ
