Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
What other measurement is there than to replace the spark gap with tensors/ev?
Quote from: Gobaga on July 20, 2010, 06:44:10 PM
Didn't you explain RE in your diatribe?  Didn't you proclaim what it is and how it is produced?  Show us the goods then, oh yeah you need $25k for a lab first.
I posted a while back that "sparks" had it figured out, but you all missed it because you were too busy spreading misinformation.
@GK
Do yourself a favor and leave these losers behind.  They are holding you back.
wattsup
I understood all of this thread except everything after post #1. lol
Just jok'in around @GK. Don't you love it?
OK, maybe I am the slow one, but for the benefit of the readers, in general writing practice, when you want to use an abbreviation for the first time, especially the 2 letter ones because they can be confused with so many other usages, you first write it in the long form then follow it with the abbreviation in parenthesis. Example: Rat Excrement (RE) or Rat Feces (RF). That's what I though you guys were arguing about. Based on the above usage of the abbreviations, then RE=RF. What else is there? OK, don't answer that.
ramset
Sup
very funny!!
Chet
Thanks Grandma
BEP
Quote from: bolt on July 20, 2010, 04:44:31 PM
The fact the columbine document has ...
Columbine?
While you at it don't just pick up one sheet of paper go and watch Eric Dollard at the Radio HAM conference search for it as you are good at searching ONE sheet of paper. He tells you you get RE = RLC RF = trashed VSWR! Now i don't give a rats ass if you are taking about a 5Hz signal or 5 GHz the method of generation the conditions for RE is exactly the same using book applied RF principles.
GO and watch he Eric Dollard vid and im not mentioning this no more. If you want to believe RE is found using other methods ..........fine whatever you like believe what you want.
"Ferro-resonance occurs when an unloaded 3-phase system consisting of an inductive and a capacitive component is interrupted by single phase means. In practice this is typical of a high voltage electrical distribution network of transformers  (inductive component) and power cables (capacitive component). If such a network has no load and the applied voltage is then interrupted on a single phase, a ferroresonance may be observed. ;D If the remaining phases are not interrupted and the phenomenon continues, overvoltage can lead to the breakdown of insulation in connected components resulting in failure."
Now any smart people here know what has happened to create ferroresonance? Let me make it real simple RLC went into a power factor Zero using book applied RF conditions and created the conditions to make RE.  The RE caused the extreme power increase and creates the damage to the circuits and transformers etc. This can easy be created and tapped, stored, collected and looped. Yes its pure RE and the transformers can suddenly see a COP>20!! Go and try it go find a 3 phase transformer, bigger the better they go RE very easy due to the mass of iron one precision ping will shake the thing to bits the iron screams and pumps RE.
The text books like you to believe that  ferro-resonance is some random ad hoc event like lightning and is hard to reproduce. But why go looking for it UNLESS you want to make RE of course! LOL
The electric companies know this they spend all their time trying to STOP RE from happening. To them its a pain in the arse having stuff explode and trip out because Radiant Energy pumped mega joules into the grid.
Now as I'm also a HAM i used to be active back in the late 80's....
No-code Technician class, I presume.
I think im qualified enough to pull information,  swirl it around in my head discard any crap and pass good judgment.
May I suggest a bit less swirling?
The difference between RE and RF is about the same as comparing SunShine to a Flowing River. They aren't the same thing either, or are they? Come on, say it..... SS=FR!
Oh well! Throw them some abbreviations with some acronyms mixed in. It tends to calm them down  :D
BEP
Quote from: wattsup on July 20, 2010, 09:18:10 PM
THANK THE HEAVENS! @Wattsup, you have clarified this for me, FINALLY.
All this time I thought he was talking about radiant energy and radio frequency. No wonder I couldn't follow the thought. Man! You know how I have trouble with all the abbreviations for TPUs? Well, same for RE & RF. Thanks to you, it is clear and making sense now  ???
