Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
bolt
Quote from: giantkiller on July 21, 2010, 02:56:44 PM
RF equals Tidal wave, RE equals Rogue wave. The final design is not only in this thread but all the other threads not just as puzzles pieces but as whole pictures which spell out the keys needed. You can do this process by spark gap or by domain flipping(some won't like this term). For the vulgar we'll call it 'Shock the monkey'.
The thread name is 'Final design' not 'Final product'.
Now this process can be run with current(Edison) or excited by electrostatics(Tesla or Dollard).
The GK4 test way back when was a current and electrostatic based test regime. When the phasing is off we use current but the closer the phasing(but not bang on) the closer to electrostatic/kinetic the process gets. This happens because of the eclisping of positive / negative or expanding / decreasing fields over different types of material. In the GK4 build it was copper and iron. Two different hysteresis curves, inpedances, resistances, atomic structures, ad infinitum.
The Kapanadze devices show 9 volt battery and lead cells. Look at how the devices run loads. The 9v run filament bulbs. Why? No real load, purely excitation. The small TPUs run loads of filament bulbs. Why? No real load, purely excitation.
Kinetic? Do ya feel the particles?
I did the stungun based Kapanadze test. See attached.
Rememer: Tesla employed multiple stages of spark gaps in 1 circuit. What you don't see is the higher and higher graduating levels of sparkage or the wire gauges.
Bolt was right. Here is fortune cookie wisdom: He who bangs coils, bangs head. He who sings coils saves head. Ray Bradbury was correct too in : 'I sing 'the body' electric'.
You will never find power as long as you keep searching for it. This is not about squeezing power from power. The power is a lower, later stage of the process. Tesla: 'Exceedingly high speed voltage and high speed currents'. He did not say current. Tensors not conduction.
It is not the tidal waves that breaks the ship but the rogue wave eclipse point that disassociates the material.
p.s. It is not about finding the correct components to achieve the correct power but the choosing the correct components that can handle the achievement.
GK put your diodes the other way to collect RE. The ground is POSITIVE so the cap to be charged is positive ground. The negative is air side and the cap charges to minus 6000 volts relative the ground. The PSU MUST float above ground so you can only use batteries.
The Radiant energy is positive and will refill the cap BACK TO ZERO. The refill is cold electricity. Everyone always puts their diodes around the wrong way and uses convention to make the earth 0 volts.
If a cap is charged negative to ground the RE being positive dont like displacement and will refill the cap as opposites attract.
By convention a positive charge cap REPELLS a radiant positive charge and leads to total waste.
The top of a storm cloud is positive charge. The base is negative the ground below that cloud goes positive relatively speaking.
This is why if you do this right you can be struck by lightning. SM told you this and ask Bob Boyce his lab was struck by lightning several times.
The only other person that tends to get this right is John Bedini. Don Smith knows but he deliberately laid out his circuits in reverse polarity to "protect investors".
sparks
  In the below Tesla patent there are a number of interesting things.  What I find most interesting is that if ac is used to deliver power to the working circuit you need two air gaps.  Whereas if dc is used you just need one.  I seriously doubt that more than one gap at a time is active.  So we need only worry about one form of electricity doing any moving about in these circuits.  Another interesting thing about this patent is the disclosure that Tesla was working with megahertz way back there.  He also states that time is gained while the portion of the circuit l is propogating a high resistance to the pulses from the sparkgap.  The capacitor is accruing the pulses from the spark gap the coil of highself induction is also charging the cap.  The electricty flowing into the coil induces a magnetic field change which induces a voltage that is counter to the exciting voltage.  So what we have now is two scources of emf dumping into the capacitor one from the sparkgap and the counteremf of the inductor.  The voltage on the capacitor rises until it  overcomes the resitance of the load.  So for each pulse from the spark gap and there is a boattload of them results in gaining the amount of charge going into the one capacitor plate over that directly conveyed by the gap.  It really doesnt matter if a loop current forms after l at all.  This is simply series resonance at high frequency.  The spark gap capacitively couples the generator with the working circuit.   As the air ionizes it takes the plates that are very close to begin with an moves them even closer.  At some point the gap between the moving capacitor plate (hot electrons in the plasma) and the stationary one is so close that the electrons in the plasma force charge to be conveyed to the working electrode.  Electricity can move faster than the speed of light because it is a force in motion not mass in motion but a a force in motion.  Quantom physics will say that it is the virtual particles that move so I guess electricity is made up of a flow of virtual particles that create the charge which the electron carry and the protons carry.  This is what constitutes an electrical current.  This flow of virtual particles that give birth to negative and positive charge.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
MrMag
Sparks,
In the patent he mentions that one or both "B" can have a spark gap. I don't think it is meant for AC or DC, he doesn't mention it. Most of his patents mentions the supply as a generator of high tension. He used both AC and DC in his experiments. As far as the time being gained, he was speaking at the moment about a single pulse. When this pulse happens, no current will flow in branch "L" as it is being absorbed by the condenser. I don't see where he mentions that time is gained while the portion of the circuit is propagating a high resistance to the pulse of the spark gap??
@All
When reading Tesla's patents, just try to read and understand what he is saying. Too many people try to interpret what he saying and that just complicates the things that aren't complicated. This is one of his more simple patents. You may have to read it a few times but there is nothing there but an explanation of the circuit and it's operation.
Gobaga
Quote from: bolt on July 21, 2010, 06:53:29 PM
RE and "diode" do not belong in the same sentence.  RE has nothing to do with diodes.
You might want to try some of the things you recommend, before you recommend them.
Gobaga
Quote from: sparks on July 21, 2010, 10:00:05 PM
All Tesla is talking about in this patent is changing the frequency of the oscillation in different parts of a circuit by changing the parameters of the circuit in the location that you want to be different.
Nice blurb on the virtual particles and force in motion - really diggin' that.
