Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
stprue
Quote from: giantkiller on November 23, 2009, 03:53:44 PM
The larger the ring diameter the larger the electron cloud effected by the field of effective aperture.
With an iron core there is current storage with field storage.
--giantkiller
I was thinking that my next test core should be one of my large ferrites.
giantkiller
I have a 10" diam x ~1.5 inches high x 1/4 wall thickness iron core that matches Don's cart coil. My NST runs @ 30khz. I will apply his math to the build and see what appears.
I was able to fire a 300kv stungun into a setup of a neon, large cap, & coil. Measured 1kva mangled sinewave off of the output side of the coil.
I see you put a bridge ic on your board after the HVosc module. I have to do that next. I used a Barkenhauser. Also, was just trying LC tank and series LC setups. Got an LED to light but no big deal. I have a box of minature HVoscs too to place in there. I used a neon as a spark gap but higher voltage transfer with the spark plug.
The stun gun oscillatoror 5khz-6khz does not match my coil's natural resonance. So I can use the 555 to an iggy or static HVosc(this would be a new coil) or wait for my NST(this would be a new coil) to arrive. The 555 would be variable. I had paralleled a cap to force resonance. Grumpy had mentioned the E and H lag time as beneficial due to this. Don says 'Yes' to this also. But I still wonder why one would match the natural wavelength then tune it elsewhere...
Also
How did you wire that rig up?
--gk.
stprue
Sorry to not get a vid ready!
Honestly I'm F....ing pissed right now because the last hour I have been trying to upload my vid of my new TPU to you and now it has crashed...pissed.......f....ing pissed.
I will make another as soon as I can.
giantkiller
giantkiller
