Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
Yes. Bias the core with HV and use the field instead of the conductor for transmission. Similar to Don Smith's back charging the battery.
I flew outa sleep this morning @ 3am realizing what this means in a ring configuration.
I have the EC600 on the way and ordered (50) 1kv@1a diodes for a cap and diode ladder.
http://www.zephyrtechnology.com/UFO_Technology/Build_Flying_Saucer_/build_flying_saucer_.html
Quote from: starcruiser on October 05, 2010, 01:29:37 PM
Interesting link GK, ran with it and found some interesting points about copper mass. Seems to relate to the TPU and the Kapandze device too. One article I read spoke to using a copper pipe or mass in the center and using a bifilar coil on one end and a pick coil on the other end of the pipe to convert the torsion waves back to EM. All using a static amg field and some sq wave or HV pulsing to emit the torsion waves.
So in the Kapandze device a large copper cable (stranded) is used for the mass. The HV spark is used to excite the Torsion output of the coil and a second coil is used as a static field. Something was mentioned about a 90° coil to the first (pickup?) or perhaps another coil is used? Ideas...humm
as for the TPU design a few wraps of stranded copper for the core, over wrapped coils for pickup and static field (or a neo magnet) and the core torrid is the converter (torsion field generator)?
In either case the mass & length of the coils is the key. Sweet...
Rosphere
Quote from: giantkiller on October 05, 2010, 05:53:55 PM
...I flew outa sleep this morning @ 3am realizing what this means in a ring configuration...
"...I flew out of my bed to see what was this matter..."  ;)
giantkiller
T.T.Brown applied high voltage to an aluminium plate which then registered lighter in weight.
He applied pulsing and this caused propulsion and velocity to a piece of mass.
Podkletnov removed the physical target then applied vectored pulsing which produced propulsion and acceleration to a magnetic density of mass but having no material properties. In other words no physical properties relating to a visible object. This magnetic mass then moved very quickly in a linear path.
Both of these men created a movable mass of high density.
T.T.Brown did not move a metal plate. It was deflected by the high density magnetic mass to a lower density area in space.
Steven Mark put this process in a ring. The Podkletnov process now becomes an inertial vortex. Time this correctly to spin the field. Place conductors in the travel path to collect the EMF.
The pulsing creates a higher density field in the High voltage, high density field of the bias. We also get fast pulse transistions which look like high density boundaries.
NickZ
  @ GK:
     Thanks for keeping us up on your ongoing ventures.
  Who would of thought that it was going to be this complicated,  getting some usable magnetic energy up and runnin'.. .
MS said that it was "not rocket science... how wrong he was.  But, once we get this one down, rockets will be a thing of the past.
    Anything "Electrifying" with your current set-ups?
        NZ
giantkiller
I had to reposition the bench to accomodate the HV to the coils. I also am going to integrate the center toroid things as readers or triggers.
I am taking controlled steps into this. No blown equipment, no headaches, no cancer.
I have my variac/ MOT monster power supply configured. I also am building a Villard cap and diode multiplier and have an EC600 4kv module coming in. I realize this is over kill compared to the SM17 but I want to manage the discreet steps.
With an HV biased copper core all coils now look viable.
The plan is to use the high density flux field as a meduim for creation of rogue waves.
