giantkiller
Cmos is voltage potential(fets), TTL  is current(transistors).
Just get the idea of high speed like Earl was pushing before.
Spark gap based devices don't have to ramp up. This circuit is a virtual spark gap that creates light potential switching to set the process going and it ramps up. The ramp up is the resonance building. We push the swing at the correct time. Pretty simple actually. When the swinger crosses the mid point is where the most potential is.
Yeah, muxes for short. The ones I found worked bi directional through the analog path.
And circuit shown was not using the Mux part at all, just the break before make part. All input lines are tied high. :P
Only the obvious lines are drawn. No clutter.
And let me reiterate. What the ckt shows is:
+9volt,
High speed switching,
Floating ground(this is part of the feedback loop)
Circuit in center,
battery operation shows float process,
Snake bites it tail(push the swing at this point),
field within a field,
low current,
resonance building(ramp up),
Feedback(circuit within circuit, Resonance, ring operation back to circuit(MOBIUS on a 4d scale))
Now get all these mechanics in place and tweek the operation to perfect the whole process.
The frequencies are close to the circumference which enables a field to push. Same process as Don Smith's ac pump charging the supply battery using the dc magnetic field of the supply line. 8)
There are just too many items in place at this juncture. It is what I have been watching for. The examples match up with the learning which match up to the realization. Now the operation based on the process will prove out.
If anybody disagrees then by all means let me know?!?!?!!? Newbies might be in a quandry. But the old heads can surely see the implications.
@Grumpy,
I will try one layer at a time. I was just posting the whole 'Kit -n- kabootle' 8)
Testing will be on the ring mounted vertical.  I suggest anybody else do the same for starters. Its not what you think. 8)
Quote from: Loner on August 07, 2010, 03:20:30 PM
GK, Thanks!!!   I think I am getting it.  I think you mean De-Mux's...
Interesting that this goes way back to the "Original" circuits I used for my first try's, though mine were TTL and my "Driver" section stunk.  This IS a great way to line up and sync multiple outputs, very cleanly.  I really wonder what this would/could do, built in CMOS and allowed to float up via non-grounded battery power.   Hmmmmm......
Rats, now you have got that little curious part of my mind working, that won't leave me alone till I try.  I'll probably go 3 to 8 line and see what happens, as digital logic and counter response WAS my original job description, before LSI became popular.  This will take a while.  (Note: old school shortcut...  If the entire "Bus" in connected, then aligning the chips on the drawing doesn't require drawing all the lines.  Just assume they are all in use.  If not all are in use, the some draw just the "Last" one, and the assumption is beginning to drawn.  Just a comment.)
sigma16
Wind up a big solenoid coil with 2000 feet or more. HT mag wire.  Insulation looks like bronze.  28 awg is good.  Doesn't really matter.  Use a hollow insulator material for the core or no core if you pot it somehow.
Hit this coil with a few KVDC (at least 2kv), through a spark gap pulse circuit.  This is just a test, so you don't need a full blown build.
Set this up and you are at step one.
giantkiller
This sounds like a stun gun to the secondary of an ignition coil if the 2kv does have current. Maintain the outer spark gap of the gun. oops. The ignition coil is not air core though. Could use a ratshack spool? Stacked 4 high to get the turns.
Quote from: sigma16 on August 07, 2010, 09:50:09 PM
bolt
No  need to go back to banging coils its been done for yeas now nothing good came of it. A single fet low powered driving 3 phase WYE can produce several KVARs for a few watts drive.  You don't HAVE to use magamps but if you do no need to use a fet and it makes the device immune (till lightning strikes anyway)  from power surges.
Only copper wires required no special cocktails of silver and iron wire required.
In order to create the desired circuit we need to produce NEGATIVE inductors. We all heard about negative resistors but the key here is negative inductors and because we must CANCEL out  the magnetic fields as much as possible in the circuit, there by keeping the total inductance of the circuit negative. We do this by creating VARS as this disturbs the ambient but there is no current flowing as there No in phase amps. If there is no amps there is no current flowing and no Lenze. If you bang the coils you create current and a magnetic field. Everything must be done in complete opposite.
A bifilar coil cancels out magnetic flux but so does polyphase system as power factor is slashed.
BUT everything else is happening the space is now highly energized as electrostatic field its pumping longitudinal waves. The i/p power may only be watts but there is several KVARs in circulation. Now there is Kinetic Energy.
As Don Smith stuff = Low power precursor (a few real watts) convert to VAR = Kinetic Energy = Device rating 50KVARS+ convert to magnetic as two converging electrostatic fields = real WATTS o/p.
Or RE = RF through RLC where OU derived from RE transformations of one energy type to another.
In the case of TPU 3 phase negative inductors create rotational electrostatic stress and not magnetic to begin the process and stores a negative energy charge in a space where the relative magnetic field appears, and as a counteraction, the inductors generates an electric power with a positive energy. The free electrons from the VARS field got  kinetic energy from a space as accelerating returns the kinetic energy to the space becomes deceleration.
The negative inductances  of the negative 3 phase inductors is proportional albeit non linear to the product of the rate of change of the relative magnetic fluxes impinging on the coils and the number of turns of the coil, like that of a NORMAL inductors but in reverse.  By raising the voltage applied either side of the exciter collector coils  the total number of the relative magnetic fluxes impinging on the WYE inductors can be increased. So the TPU is a sandwich where we have rotating electrostatics (Not magnetic to begin with otherwise you need current and 100 watts of coil banging only gives you a headaches and eats the power supply) where a HV positive and negative DC charge is applied. While the atomic level dynamics drops the heat out of the device the rotational electrostatic fields create eddy current when driving a real load as now we have REAL amps flowing. Note electrostatic does not mean DC static from my standpoint but much closer related to RF where the nodes are either Zero or Max and not NULL. Null means nothing so bad use for this.
The device is vertically polarized from this charge as the ambient is polarized from earth to space.
In kapanadze the process is actually very similar but instead of 3 phase he using single phase 50Hz as the negative inductor is a VARS tank. In fact its a tube homo-polar transformer where the PF = ZERO or VSWR infinity so its an electrostatic device to begin with not magnetic. The HT DC charge is applied between the inner and outer non magnetic tube copper will work fine. OR it can be separate layer windings.  Whatever method is chosen its important the MASS is identical between the inner and outer layers. (close as practical)
Now the conditions are SET they need moving side to side to induce a REAL current with amps and volts in phase. So the 50 Hz push pull sine wave driver modulates the HV so the action is a side to side motion of two interactive electrostatic layers. The coil becomes a NEGATIVE inductor and so the normal entropy bell ringing to loss becomes GAINS of increasing magnitude while taking up ambient atomic thermal heat energy drops the inductor through its negative. With this is mind the spark gap only requires just enough to create an arc 2kv perhaps and hardly any current.
As Tesla said "Don't underestimate the force of electrostatics" .
SkyWatcher123
Hi bolt, those are interesting thoughts. I was a couple days ago just thinking about bifilar coil and why could we not somehow induce energy into another coil from the interplay of the so called canceling fields, though it sure sounds like your saying the fields under a certain condition can generate power for us. That rings true to me.
peace love light
Tyson
