We are entering the competition officially
Started by ltseung888, October 30, 2009, 10:32:04 AM
ltseung888
Dear All,
We want to state that we are entering the competition officially.  We shall build 3 prototypes that will demonstrate overunity beyond any shadow of doubt.
The Name of our machine is "Lead-Out Energy Machine".
The details are in the Lee Tseung Lead Out Energy Thread.
We shall first enter Three Open Shows.  The first one will be Nov 5-8, 2009 at the Inno Carnival 09 in the Hong Kong Science Park.
You are welcome to attend.  Admission is free.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
Paul-R
We are all (at least most of us) wishing you well, and following your progress.
spoondini
When are you sending a unit to Stephan for verification?  That's what officially enters you in the competition, not the trade shows.
powercat
I hope you win, we are all fed up of being ripped off by the energy companies.
All the very best
      cat
ltseung888
Brief description of the 3 identical prototypes for the Competition
The rotating wheel diameter will be 60 cm.  The non-rotating wheel diameter will be 90 cm.
The outer dimension including the packaging material for shipping will be 120 x 100 x 35 cm.
The weight is estimated to be 50 kg.
It will contain:
1.   16 permanent magnets equally spaced in the rotating wheel.  These magnets may be adjusted and even changed by other permanent magnets.
2.   15 coils that can either become drive coils or collector coils.  Each coil will work with one magnet.  One slot will be reserved for the Proximity Switch.  In other words, 15 coils will face 15 magnets and 1 proximity switch will face the remaining magnet.
3.   The adjustment of the Proximity Switch is extremely important as slight change in its position and angling will speed up, slow down or allow the wheel to rotate in the opposite direction.
4.   There can be an optional wheel attached to the axle.  This additional load can be a small wheel with small magnets to affect the strong magnetic field in the big wheel.  Some fine tuning can be done.
5.   Some of the coils can be used as Collector Coils.  The arrangement can be in series and/or parallel.  This is the most important item that affects the Output.  Some additional coils can be inserted.
6.   The Output Current is AC and should be rectified (converted to DC).  This DC Output can have voltage higher than the 12V battery and thus can recharge the battery.
7.   The load can be one or more light bulbs.  The smallest ones we use will be 12V 3 watts.  The largest ones we use will be 12V 30 watts.
At present, much tuning is required before overunity can be demonstrated (as calculated by the Input and Output meter readings. )  There is an additional feature that we have not used yet.  Our Drive Coils effectively act as Collector Coils when they are not Pulsing.  This may be a bonus feature in the delivered prototype.
To avoid any chance of the untrained Evaluators not able to tune the Lead-Out Energy Machines, we may have some of the trained engineers to do the tuning when the Machines are delivered.  In addition, the Machines will not be shipped until the experts in Hong Kong and China give their Official Blessing.
