Thanks to ALL for your help!!
The Power of Gravity - You might find this interesting.
Started by ResinRat2, October 30, 2009, 01:54:52 PM
ResinRat2
In a thought experiment of building a mechanical battery I found the following calculation very sobering.
In order to simply store the equivalent of One Kilowatt-Hour of energy the following is required:
One Kilogram of water falling one meter produces:
(1 kg water)(9.8 m/s2)(1 meter) =  9.8 kg-m2/s2 which is equivalent to
9.8 Joules of energy
1000J/s for one hour is One Kilowatt-hr of energy
(1000J/s)(60sec/min)(60min/hour)  =  3.6 million Joules .
In order to store this much energy by raising a weight to a height of  3 meters we would need a total weight of:
(3600000 kg-m2/s2)/ ((9.8 m/s2)(3 m))  =  122000 kg. raised to a height of 3 meters.
For those of us in the United States it is equivalent to approximately 134 Tons raised to a height of approximately 10 Feet.
Wet sand weighs approximately 2.3g/cm3 or 19.19 lbs/ gal
A single ton of this heavy stuff would require 53 cubic meters of volume. Multiply this by 134 and you can see why energy is never stored by raising a weight, and why a gravity-based battery has never been economically developed.
For the first time in my life, my old sore knees being now ignored, I am looking at the reality that the force of gravity is a very weak force indeed.
spoondini
Resinrat,
   On another post somebody had a very clever idea to perform electrolysis, take advantage of the natural buoyancy of hydrogen and let it rise in a tower, react with oxygen from the atmosphere (burn) at altitude and capture that energy, the capture the hydro power as the water fell back down.  A perpetual water fall if you will.  Sounded great to me.  I did the math and after taking into account efficiency losses, I calculated the tower would need to be really freeking tall, like stratospheric to even break even.
Are knees certainly don't perceive gravity as a weak force, bu math sure as hell does.
sm0ky2
or using water instead of sand, 1 gallon weights 3.787 Kg
so,  1 KW-Hr is roughly 32,220 gallons per hour, or approx. 550 gallons per minute through an hydroelectric generator.
with a drop height of 9.8 ft.
size = its about a 20-ft by 40-ft / 5 ft deep swimming pool.
completely dumped in 1 hour.
ResinRat2
Yes, the math does show what a pittance of energy gravity potentially can store; but doesn't this also hint at the fact that even if a perpetual motion wheel could possibly be invented, it would require such a large number of them to produce even a small amount of energy from gravity that it would be a waste of energy even building them?
I originally thought of digging downward and building the mechanical battery with a shaft in the ground a hundred feet deep. Even this would require such a large weight (over 13 tons) that it was ridiculous to even consider it.
TechStuf
Yes, but consider that such an eventuality is not really about gravity wheels at all....
But instead, certain tangential possibilities.
From there, a single great leap is possible.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
