Getting amps from small selfmade DIY Zinc Air cells, amazing !
Started by hartiberlin, October 31, 2009, 10:14:09 PM
MW383
Read the following Zinc Air Battery patents. Should aid construction efforts for those building these things.
http://www.freepatentsonline.com/6461761.pdf
http://www.freepatentsonline.com/6296961.pdf
http://www.freepatentsonline.com/6261709.pdf
http://www.freepatentsonline.com/6203940.pdf
http://www.freepatentsonline.com/6197445.pdf
I can personally attest to the capabilities of this battery chemistry in regards to power aspects.
Cheers!
hartiberlin
Hi All,
as I look on the graphics of:
http://www.revolttechnology.com/res/photo/-11.battery_layers.jpg
it might be, that they put the KOH eletrolyte just into a gel based
solution, so the electrolyte is just not a liquid , but a gel.
You can get cheap gel salts, that bind water and other liquids from
diapers via Superabsorbers ( PolyAcryl-Salts)
See here:
http://www.chemieunterricht.de/dc2/tip/09_05.htm
Translate it with Google.
hartiberlin
Via the gel based electrolyte it might be easier to recharge the cell
without the KOH destroying the cell.
hartiberlin
Hi All,
today I bought Pottassium Permanganat
(in German language Kaliumpermanganat KMnO4)
and I want to mix this with lampblack (some kind of conductive graphite-carbon) and an acrylic binder
to produce one eletrode of the battery.
Do you think this will be dangerous ?
As Pottassium Permanganat (KMnO4) is a very high oxidizer and can selfignite with some
other chemicals like Glycerin (glycerol)
how should I prepare this without blowing myself up ?
Maybe it is best first to solute the Pottassium Permanganat into water and then
add wet lampblack and then add the acrylic binder ?
Will this get hot ?
And then let it dry ?
Could I heat it up a bit to get it faster to dry or will this explode then ?
I want to use this as one electrode and use KOH or K2CO3 in water as the electrolyte
and Alufoil or a Zincplate as the other electrode for this airbattery...
So will I blow myself up, if I will try this or what other precautions should I take ?
I don´t want to get my fingers ripped away from an explosion.
I know how dangerours for instance Acetone-peroxid is,
with which I played in my younger years and that exploded
already by hit with a hammer !
Please let me know.
Many thanks.
Regards, Stefan.
onthecuttingedge2005
