A validation of the UP-SIDE-DOWN phenomena
Started by EMdevices, November 02, 2009, 09:40:48 PM
innovation_station
the core ...
well em
i found the material for my large rings W material works well 10 000u  but i think it may have to do with  tuneing the core first ...
the 814 14 ga  works well for a 1 " core
but even so  with many cores the exact same you must tune first ... perhaps  some are just  poor quality .. i have noticed  identical cores .. to the eye but very diffrent story when tuneing .. for output!
i first do this to find how many turns on primary of core ..  once primary is found .. for best results .. i then place secondary wires to my desired voltage..
the most i ever got from a aa battery and  a 1"  was  680vac pure sine ... ptp no bridge...
so now  may there not be a way to convert your transmitter to operate from a jt...  ;)
i bet there is ...
is
turbo
Mannix....Incorrect houses remember?? are you going to rethink that statement?
EM Devices,
What can you say about the distance between the house and the powerlines? in Meters
I just want to know how close you think it was.
If you happen to know the voltages these lines carry it's even better.
Marco.
innovation_station
this is brilliant!
;D
so sm orignally built the tpu from plh
he then made a slick little unit ... all in 1
wonderful!
he then learned he could just tune right into the  source?
ist!
hartiberlin
Hi EM,
nice setup and great output !
Yes, you should really check,
if more receivers will also draw more power in the transmitter.
But: There are videos, where SM did show his devices
not near power lines, e.g. on the Hifi-Rack( which probably shields this),
the white room with no furniture in it with the 2 x 60 Watts lamps
and he also showed it to Dr. Schinzinger probably at the university,
when I remember correctly...
So it is very vague to say, that it only worked near power lines.
Well, try to measure the input power into your CFL transmitter
circuit and then compare the output power from several
receiver coil bulbs.
Will be interesting to see, if you will get more output power
than transmit power put in.
Many thanks.
Regards, Stefan.
WilbyInebriated
Quote from: EMdevices on November 17, 2009, 12:49:03 AM
I thought I knew all there was about resonance,.... how wrong I was !)
that's the smartest thing i have heard anyone say on a TPU thread. it's too bad you didn't have that humility sooner, you might have learned something from stiffler regarding multiple receivers.
Quote from: EMdevices on November 17, 2009, 01:10:55 AM
it does not work when the power is cut off to the whole house
so what's the big deal then? when you run this device, it still spins your mains meter faster does it not? get it to work with your house power shut off and you have something...
