Water Level Sensor for HHO cell
Started by Draco Rylos, November 03, 2009, 12:33:21 PM
Yucca
As MW383 says, continuity based sensors can be a bit temperamental. But as you are reading the sensor with a microcontroller I would advise going with continuity sensor just because its solid state and reliable and the micro can filter out glitches using the scheme below:
I havent built HHO system with micro but I´ve done various other work in industrial systems.
You can use small stainless fasteners through the side wall of your tank with synthetic washers. Place fasteners quite a few cm apart at fluid full level through the tank side. In sticky fluids you have to go on opposite sides of the tank.
I always read the voltage using an ADC pin if I have one available because you can tweak the HI and LO thresholds in software.
In the micro read the sensor pin once a second. If you see the pin change state HI to LO and then it holds the new state for 20 more seconds without interruption then treat it as a drop in fluid level and run the 12V pump.
Some systems use two level sensors, lower one to trigger pump start and higher one to stop the pump, but I always use one sensor and when I see a 20 sec state change I just power the pump for a preset number of seconds and then stop it.
Draco Rylos
My HHO cell idea didn't start off using a uC, but it evolved into using a PIC. I'm using a PIC16F690 as the heart and brains of my switching system.  I've got the logic down pretty simple
(Operation)
Upper (RA1) + Lower Sensor (RA2) = 1 Then Operation (RB6) = 1; Warn (RB5) = 0; Refill (RB3, RB4) = 0
Upper Sensor = 0 + Lower Sensor = 1 Then Operation = 1; Warn = 1; Refill = 0
(Refilling)
Upper + Lower Sensor = 0 Then Operation = 0; Warn = Flashing; Refill = 1
If Lower Sensor = 1 + Upper Sensor = 0 Then Operation = 0, Warn = Flashing, Refill = 1
If Upper + Lower Sensor = 1 Then Operation = 1; Warn = 0; Refill = 0
(End Refilling)
But I've changed how the system is set up, by swapping out the LEDs that were represented in this logic diagram with a 2x20 LCD. Port C is my LCD output, Port B is my General Outputs, and Port A are my inputs, with RA0 being my ADC port with the preset, and RA1 is the upper sensor and RA2 is my lower sensor. I have the rest of my pins pulled to ground with 10K resistors, except for my clock inputs.
We are the BORG..... We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE
Yucca
cool, are you going to do PWM with the PIC too?
Draco Rylos
No, I'm going to use ZeroFossilFuel's current limiting Pulse Width Modulator. The Power on/off will be controlled by my control circuit along with the refill valve and the pump on/off switching.
Yucca
That´ll work well. Have fun and good luck with it.
