Bob Boyce Hex Controller
Started by sterlinga, November 12, 2009, 12:48:28 PM
Eighthman
Can somebody tell me what the "danger" is as referred to by Boyce and Watky-whatever1 guy?
Is it some threat by MIB types to give cancer to anyone who succeeds?  I don't understand.
Thanks,
Eighthman
Bruce_TPU
P.S.  I wrote that entire Bob Boyce PDF, and may release it all soon.  And this copy is missing three fourths of it.  FYI
Cheers,
Bruce
gmeast
Quote from: Bruce_TPU on March 06, 2012, 08:57:43 AM
Cheers,
Bruce
Hi Bruce,
I've enjoyed your series "How to Build ...... TPU" and can't wait to jump in on that, but I've committed myself to first finishing my PPC project ... "PPC" stands for 'Poly Phase Controller'.
The allure of Wacky's 'self charging battery' demo on YouTube captured much attention.  I set out to replicate it, but simply refused to commit to learning micro-code and all of the hardware issues, accompanying.  I also noticed that interest went cold with other experimenters too ...  just because of the 'micro-thing', so I set out to design a poly phase controller based on the building block principle that uses a silicon oscillator clock for precision, a frequency board and 1 or more phase boards ... all simply controlled by DIP Switch Input to establish Frequency & Phase Angles ... and NO programming skills required.  The stability is as good as with a micro, but I can't compare resolutions yet.  Right now I'm only thumping along at 4MHz clock speed.
Some of you may have already seen some of this development on my YouTube channel "gmeast".
I finished populating my first phase board PCB and 'cabled' it to the frequency board PCB.  Below is a picture of the complete setup:
I have had several very good and informative private email exchanges with Bob Boyce with regards to some specifics dealing with choke specs, controller placement (relative to the Toroid), other specifics re: the MOSFET driver ... which one? and he says the UCC27322 (non-inverting) driver chip (with inhibit) is the way to go .... and more ... and also offered encouragement and NO 'negatives' as for what I'm trying to accomplish in hardware.
Anyway, best to you Bruce and everyone,
Greg
Bruce_TPU
Quote from: gmeast on March 06, 2012, 01:46:28 PM
Hi Bruce,
Greg
Nice work Greg.  People seldom realize that Bob too uses harmonics but in a different way, with his hydroxy experiments.  Send me a pm and let's chat.  I would gladly send you the complete PDF if it might assist you in your work.
Cheers,
Bruce
plengo
Hi Bruce,
Greg
Hey Greg,
I am eagerly watching your videos now. I am very interested in that project. Can you share some of the info Bob gave you?
Many thanks,
Fausto.
