Water pressure potential
Started by drakcore, November 13, 2009, 06:57:10 AM
onthecuttingedge2005
also remember that the correct diameter of the capillary tube is the science behind getting the liquid to draw up the tube properly. the smaller the inside diameter the better.
the tube on the far left is the same diameter as the ink tube in a standard disposable ink pen.
the green liquid is colored water.
drakcore
Quote from: truth on November 13, 2009, 02:49:01 PM
Which device will be the overunity one? The generator or the pump?
Due to the parodox it takes the same peressure to lift the water as you obtain by letting it fall.
simple math
water pressure at base of tank = 1
pressure required to lift water into tank =1
Friction loss  = greater than 0
net result negative greater than 0
The water applying pressure would be the overunity medium to transfer gravity to a workable form, the generators using the pressure would the part transferring that potential to electric and the pump would be used to "close the circuit".
Water pressure at the "base" of a pipe of equal diameter and length (same dimensions) of another pipe and you would need the exact force+a little more to move the medium inside in that direction of the strongest directional force.
A tank containing allot more water / pressure / "water flow" than the pipe pushing it back into the tank I think is a different story.
*REF to DIA 1 and DIA 2.
So what stops us from simply putting a pipe at the base of the tank connecting it to generators and feeding it back into the tank?
Everything wants to balance in one way or another, so the water (medium) in the pipe will the same level of the water in the tank and all the pressure/potential will be lost in the tank/pipes.
*REF to DIA 3
DIA 4 is a simple example of breaking the balance to utilize those potentials.
DIA 5 is a more efficient system.
*Note the pump at the bottom at the end of the generators is used to complete the system using some electricity made by the generators to pump the water back into the tank.
*Be careful to use a pump in line with the requirements of your system.
truth
"DIA 4 is a simple example of breaking the balance to utilize those potentials"
I am sorry to inform you that this statement is false!
When the closed system is broken the water level becomes that lower OPEN receiver, the pressure in the tube lowers, and the new water level becomes the SAME as the water level in the LOWER receiver!
If only it was simple?
Truth
truth
http://en.wikipedia.org/wiki/Hydrostatic_paradox
Check out the link and you will see what you seem to missing!
Truth
TechStuf
Perhaps there is greater promise in centrifugal systems.  Making use of prodigious pressures made available through a liquid flywheel.  The following is a simple 'thought experiment', rudimentarily demonstrating but one potential mitigation of the resistance to rotation of an outwardly migrating liquid mass in a centrifugal system.  As there is very little fritction in such a system, nearly all resistance would come solely from the outwardly migrating liquid mass.
Google, Schauberger Trout Turbine.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
