Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
0 Members and 23 Guests are viewing this topic.
Liberty
Quote from: kingrs on September 06, 2006, 05:11:26 PM
Hi JackH,
Just reading between the lines here,feel free to correct me.
I would guess that you have gone for a wind turbine assist motor as this will not draw attention to itself, wind turbine still turns, still generates power (although more than for the given wind speed) and everyone is happy.
No laws appear to have been broken, its good clean energy that everyone can buy from the grid.
Simple, no need for the oil people to worry as you would probably need to cover vast areas to generate enough power for the whole country.
Hi Liberty,
Sorry to hear that you cannot share your idea, you are such a tease....
Well please keep us up to date with your progress.
Rob
Hi Kingrs,
I'm sorry about the secrecy.  I don't mean to be a tease.  I dislike having to do that personally.  The patent rules say that I can not have a public showing of the device explaining how it works (and it takes a long time to get a patent).  I don't make the rules, but I have to follow them if I want to have the option for a patent.
If I could say that I was the inventor and be rewarded for the idea with royalties, I would have no problem with sharing it.  But this is the system and how it operates and I must operate within these parameters.
Liberty
Liberty
PaulLowrance
Liberty,
After you publish you have one year to patent. Nobody can claim your patent during that year. Or you can file for a quick, cheap, and easy provisional patent which gives you one year.
Sounds like the ignorant old school thugs have threatened Jack. If so then I wonder what they said.
Paul Lowrance
MeggerMan
Hi,
After looking at the Tom Bearden website I found the patent and came up with the following simulation in femm.
It works slightly different to the other designs I have done in that there is two input coils that are switched on alternatively.
From what can be seen in the patent the output coil creates some 1500v at 40mA peak, and with RMS taken into account the power appears to be 25W with about 10W input.
The core I have simulated is not the same but I could change it quite easily to match it exact.
The Tom Bearden design is as follows:
http://www.cheniere.org/references/MEG_Patent.pdf
The centre core PM is 40mm height, 25mm width and depth 38mm.
Input coils are 40 turns of 18 gauge copper wire.
Output coils are 450 turns of 18 gauge copper wire.
The core is 90mm hieght by 135mm wide and depth 70mm.
Switching frequency of 87.5 khz.
No mention of the PM material used.
From the text it says that this device produced up to 48Watts with only 14Watts input and at each stage it was always over unity.
Sounds like you cannot fail with this design.
Something unrelated, a water ionizer that I have been building as a health drink, needs a complete re-design as the current density at 12volts is not high enough to charge the water after 7 hours solid:
More pics here: http://i100.photobucket.com/albums/m25/kingrs
Rob
PaulLowrance
Sterling has created a nice page for those who would like to publish at no cost:
http://peswiki.com/index.php/Tools:Documenting_Prior_Art
Paul Lowrance
dingbat
JackH - any test results to report?  you posted a long time ago that you are having independent tests done on your motors.  did you get any results?  when can i buy a windmill with your motor? any news?
