Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
0 Members and 68 Guests are viewing this topic.
Omnibus
@Eastwood,
I don?t think the problem is so much in the conspiracy and suppression as much as that continuous production of excess energy (self-sustaining device) hasn?t been demonstrated properly and that?s the reason why the world doesn?t accept it as a real phenomenon.
Honk
Hey Jack!
Can I ask you if you have run your motors for several weeks during heavy load and then
measured the output both in the beginning and at the end of the test phase to see if
there is any difference?
Magnet Power equals Clean Power
JackH
Honk
Thank's for your fast and great reply.
That is good news.
As you probably know by now, I'm planning to build a Hilden Brand motor myself.
But it is like you say "a lot of work". Right now I'm in the cad and planning stage.
My design will be a three phase, one valve per phase, using 2x2x1 inch N50 magnets.
It is a lot like your big motor in the pictures you posted.
But I plan to use just one single magnet per valve.
Calculations show that the gain in force between a single magnet vs two stacked
magnets are not that great, approx 20 pounds. The power difference between 2 vs 3 stacked magnets is really small, like a pound or two.
When doing calculations on the electro magnet I discovered that a narrow 1 inch
wide area will achieve a stronger field than a longer one at the same depth of wires.
It seems like the magnetizing force is more efficient in a narrow electro magnet.
At work I've got a 3 phase generator for free. It can deliver 750W, 105V at 3000rpm.
I intend to create a self runner of the motor and this generator if it is possible.
I'll adapt the voltage from the generator to fit the motor using switched electronics.
I will also design a 3 phase motor controller to help me power the electro valves.
But as usually there is other things in life than building motors, like family and work.
I think it will take me at least 3-5 month before it is built.
FredWalter
Quote from: Honk on February 26, 2007, 01:44:12 PM
I'm planning to build a Hilden Brand motor myself. But it is like you say "a lot of work". Right now I'm in the cad and planning stage.
Please start post your work-in-progress cad files.
