Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
hartiberlin
Hi Jack,
many thanks for all the additional infos.
You have made really a great invention.
I hope that your patent will also bring you some benefit from
it and that your motor is soon produced by a company on a bigger scale.
Many thanks !
Regards, Stefan.
Liberty
Quote from: JackH on July 18, 2006, 04:39:11 PM
Hello MT,
You need more than just washers around the magnets to make them none magnetic.  There needs to be also endcaps, like the two field pices on each end of the magnets.
Hello z_p_e,
The strenght of the magnets has alot to do with how much power is needed to equial them.  I have been using N48, it takes 8 watts of power no mater how big the magnet is.   In other words, a one inch magnet takes 8 watts, also a three inch magnet takes only 8 watts if it is an N48. This is one of the great things about this valve.  No mater how big the magnet is it still only takes 8 watts of power to turn it on.  etc, a very large machine could be controled with very little power.
Hello Greg & Gregory,
Yes I have tryed to build a solid state generator, and yes it did work, and yes it is also covered in the patent.
Hello hartiberlin,
Well I guess you could just use Iron wire.  But I chose to use the Iron cylinder because it will give I think better results, plus the fact you can build the coil out of copper wire, much less resistence to electric flow and also it can be very esaly wound for any voltage you want.  And yes the rotor also has magnets in it.   I tryed it without magnets, worked good however with magnets in the rotor you end up with large amounts of torque.
Hello Drak,
Drak I have not tryed this idea with any other magnets than neo's.  I would think it would work with any kind of magnets.
Jack, are you going to produce your motors yourself, or have you found a place to do that for you?  Also, do you plan to run your own company, or join up with another?
Liberty
Liberty
jake
QuoteI wonder if 'Jake' is still following the board to see a design that uses magnets?
Lib,
I'm listening, but not really posting any more.
Jake
Liberty
Well good Jake,
I'm glad you are still out there.  Good to hear from you again.
Liberty
Liberty
Liberty
Quote from: JackH on July 18, 2006, 09:36:11 PM
Hello Liberty,
Well I do not know just how I am going about things at this time.  I really would like to start a small company and manufacture these things myself, but the money just is not there.    I am still hoping that I can build a self running motor/generator out of this thing, but I do believe that I will need to buy some larger machine shop equipment to do that.   It seems to be that the larger the magnet you use the more efficiency you get out of the valve, but my machine shop will only allow me to work with no larger than two inch magnets, even with the two inch magnets, it has been very hard and time consuming to build a motor.
I only hope that I can hold my investers off for as long as it takes for me to build a self running motor/generator.  If not it will probably be sold to the highest bidder and may be put on the shelf.  And NO,  I do not want that to happin.  That is why I realeased it here.
Later,,,,,JackH
Perhaps you could just license the patent to other companies, forgoing the cost of construction yourself (while maintaining control of the patent).  However, you may have to go to those companies and present your motor and demo it for them with the stats as you have done here.  But you have a very nice product and a very good idea to go with it.  You will do well.  Perhaps some of your investors will push the motor to these companies for you, to help solidify their investment returns by licensing the patent to these companies.
I wish you well and admire your work.  It's a work of art.
Keep in touch and let us know how it is going and how your generator combo comes out.
Liberty
Liberty
