Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
innovation_station
gadget i dont think you should...
ok just 1 time!
tip ...
the more you take the faster it runs ...  ;)
i have self accelerating pulse motors
that operate in this manner ...
more i take faster they spinn!!
the jt will not do this properly as per its design ..
w
gadgetmall
on going experiment with 7 year old nicad brought back to life several times when new was 850mah . As you can see the Bcap is charging still gathering volts+ Amps . I am only concerned with  how much voltage will the old battery fill the Boostcap to and how much time .After this test is complete . i will redo the test with the Eneigizer everady 2500ma AA battery ni-mh and graph it again except on the same page .. It appears this old battery will run for a very long time but i am not getting the same results as the newer ni-mh batter with way more amp hours .2500mah to be exact . This will more than likely go Ou in  several more hours ,days ? Anyway . i have aduplicat circuit and the Ni-mh is charged up now and i am ready to repete Experiment 1 . Full Aa Battery Charging an ultracap up over the Unity of the run battery to a higher voltage and a much higher amperage . ie aa battery =2.5 amps@1.5 volts  and charged Bcap will be 2.5 to 2.6 volts @ or above 3000amps
Time           RUN                CHARGE
6:45 pm         1.495              .544
6:50 pm         1.438              .550
10:50pm        1.358              .605
11:10pm        1.344               .803
12:20am        1.334               .846
6:05 am        1.310               1.000
9:18am         1.304               1.048
9.59             1.303                1.058
11:08 am        1.300                1.076
1:10pm           1.298                 1.103
5:15pm            1.294               1.149
9:08pm             1.293                1.190
10:30pm            1.291                1.205
11:50pm            1.290                 1.218
8:48am 24th       1.285                 1.295
1:40pm               1.283                 1.333 :) getting there with old battery
also i started My Experiment 1 redo test but i will not report My numbers to keep it all on one page . sooo . I'll writh the numbers down and then post when its charged !! If anyone is intrested in my bad battery experiment with duplicate setup i will stop posting the number when it reaches unity.I cant edit post after a days and i dont want to clutter up this thread . thank you . you all carry on ..so far the old battery as you can see is dropping about almost 2 to3 tenths of a volt so far BUT look what it did !!No one else did this experiment but me ney sayers thasay this is nothing new????? see you all in a few days with the results .l8r
Gadget
hartiberlin
Hi Gadget,
why do you quote always 3000 amps ?
This is very unrealistic, as your load resistors will have not such low
ohms to allow at all to flow such huge currents..
Also these high amps (maybe in the 100 amps range only) would  flow only for
a few seconds, until the supercap will be discharged.
But have a look at:
http://www.overunity.com/index.php?topic=3457.msg210654#msg210654
where Dr. Stiffler measured already an energy gain during charge and
discharge intervals in  supercaps in my opinion.
Maybe this is the effect you are using to get a COP > 1 ?
innovation_station
do you recall what was revieled ? the day the music died!?
the marching band will never cease to yeild  ;)
http://www.youtube.com/watch?v=uAsV5-Hv-7U
innovation_station
what if we built a unit that you could call lightning ...  and use that bolt .. as a blast off ufo system ..
could be the univirses  first!  :P  worlds first ...  thats so first grade... lol
ist!
BTW im no diffrent than ALL of you ......
