Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
0 Members and 42 Guests are viewing this topic.
nievesoliveras
Quote from: gadgetmall on November 21, 2009, 09:45:11 PM
Hi thank you for the video and your contribution here . This was using a fat piece of wire looked like maybe # 22 ? #20 ? You take a high Resistance nichrome wire coil and see the heat that can be produced . . Also more resistance and thinner wire longer run time and hotter heat . this is what i saw . and you can see it will light a cig up nicely . I do not get why some people cannot see that there is over unity in this charging from 5 1000's of volt . heck even if it took a half a volt to charge it up from the aa battery its still over the unity of the run battery ? Right ? Someone ?
Gadget
I think that what the people want to see is that the source battery get its voltage back after doing the cap charging.
You must include some kind of feedback to the source battery in order to get a complete overunity system.
Remember that this is only my humble opinion. I can be completely wrong.
Jesus
Groundloop
@gadgetmall,
Your 650 Farad capacitor can store maximum 2197 Joule =  0,61 Watt/Hour at 2,6 Volt.
If your JT did use 13mA/h @ 1,495 Volt, and it ran for 14 hours, then the total input
usage was 0,27 Watt/Hour. The total COP = 0,61 / 0,27 = 2,26.
Congratulations! :-)
With that high COP it should be possible to make a self run circuit.
Alex.
innovation_station
btw gl that was only the first STARTER CHARGE FOR MY CAP MOTOR ...  ;D 8)
the damm aa will start the thing 40 times or more ....
think bout that ....  ;)   my output will be 5 of those caps as per orignal design ...  i then CLOSE THE LOOP VIA 12VDC STEP DOWN ADAPTOR ...  excess goes to a 1.2kw invertor
THIS IS MY !CUBE
AKA THE GOLD RING
bla bla
ist!  ;)
no body wanted to fund me ..... so i spun the shit up ...   and now you caused the release of it ..
you now have PROOF!
and im telling you all i solved teleportation and transportation  and i can explain electricty what it actually is ...  369 you name it ...  i also have aquired special skills  ;)
so play games ...
my words never changed ..  you were to blind to see..  :) :)
btw that video is jason ...
and i would not doubt he is the owner of the picture that triggered me to design it ..
anyone talk to jason anymore?   he should join in here !
btw i mean no harm dissrespect or hard feelings toward anyone ...  even farra ... imagine ...
there is something called FORGIVNESS WHERE WE COME FROM ...
its about you learning about creation ... and how you better respect it! or she is gonna bite you ...  ;D
gadgetmall
Quote from: Groundloop on November 21, 2009, 10:33:30 PM
@gadgetmall,
Alex.
Good Gracious . Thank you so much for coming in Groundloop / Man i do respect your work . Yes its no problem with a small 5/1000th of volt loss . actually just hit it with the charged cap for a few seconds and the AA as back to the original 1.495 volts . Easily  done and i welcome replications and improvement .  This started when ist asked me to post  will a NORMAL jt charge one of these Bcaps . the Answer Is YES it will . several times over . But By accident and adjusting it to pull 13 ma from the start  and hooking up those secondary leds for an on indication the circuit likes ultracaps, a lot and rings good at the current windings .  I'M used to making a primary with lots of winding thus dropping the input current even further .. Like primary 50 /100 for the secondary  instead of this 11/22 . Lots of room for improvement and i want your help here please .And thank you so much for the Math . Did you take in account for the power dissipation  total from the pdf specs on the Maxwell web site for your joules calculation ? never mind i'll take you word . either way if you replicate you will see the exact same thing . I promise . We can use your help here if would . I need a Circuit that connects the charged Bcap to the primary battery for 5  to 6 seconds approximately 13 to 14 hours into the charge to make this circuit self run and produce light and After that Initial Hit  i then need the bcap to swing into operation so it can fire up nichrome wire producing Heat regulated by a thermal cut off  untile it reaches about 1 volt volts and ahalf . I can handle this . part . I think its just a matter of a555timer circuit connected to a mosfet to fed the primary and make up for the tiny loss during Charging period . >>??? then the process needs to start over again when the bcap reches about 1 volt or just below unity and charge it back up to 2.6 ,hit the primary aa  and then produce heat all this time the light is free as well . what do yall think? When i win . you all get a Share . or even better i will include the main group who have contributed constantly . i know and you know who you . i think its over 10,000dollars ??Could we use the Christmas money ?
Gadget
Groundloop
@gadgetmall,
I have some work ahead on a battery switch etc. but will try to get some super caps
and do a full replication on your circuits later on. I do have a 12,5 Volt Dynacap, do
you think it will work on Dynacaps also?
Alex.
