Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
gravityblock
Quote from: gadgetmall on December 02, 2009, 08:08:40 PM
Also there is no way to charge these caps up in seconds unless you got access to a 200 amp charger.
Homopolar generator produces constant DC and could easily achieve 200 amps to charge those caps up in seconds.  Rotate a conductive magnet with the cap being the stationary external circuit.  Voltage shouldn't be a problem, since the voltage can be increased with a few simple techniques.  Not very difficult.
GB
Edit:  Don't forget about the Wiegan effect.  Could it be used for the one volt switching circuit?  Wrap a coil around a Wiegan Sensor as shown below or use an electromagnet to trigger it.  The coil would need to be AC.
nievesoliveras
@ist
That circuit looks interesting.
I labeled it so we are all understanding your ideas.
Do not abandon it now. Follow the idea.
Jesus
innovation_station
thank you jesus ..
i do understand this litterly years ago now ...
it is easy .. there is no pot in it the chokes are the fine wire cores .. the 815 are the kickers ...
much like my arc reactor ... put a push button on it ..
push the button .. study what happins ...
i cant draw well   when you turn it on AS SHOWEN in my original dwg ..  THIS IS WHAT HAPPINS
the cap is filled dirrectly then engery wiggles its way through the chokes to the cap .. then release it ..  it will want to flow back to the switch ... i dont let it as per the design ... so it is rectified and sent to the OUTPUT CAP with the first pulse the choked engery and now the colpase ..
this is a SIMPLE SAFE WAY TO RUN WITH GAIN ..
w
being that this set up is tuned ... mass to mass that means it should work any speed ...
we will find it perfers to work best at its tuned resonance .. and then intrupted ..  but we wont go that deep for now with this simple design ..
nievesoliveras
innovation_station
yes that is correct ...
take note   bridge can be subbed for diodes and can allow for npn and pnp switching ...
i will build a small unit when i finally finish paying for my parts ... tonight i hope .. as i have been told .. see how it goes ..
all i can do ...
can you understand how this works jesus ..  thank you for my drawing ...  i need to repair my computer i then will draw in corel draw some nice clean designs and ways this can be configured ..
this is teslas work ..  i can find a few pattends ..
if i need to
ist!
now i need to say more ..... errrr
this design may allow for many advancements to it yet ...
1 any number of tuned coils may be added ...  the placement may be played with ...
honestly ...  i can improve way beond what you can imagine .. currently
look at this pic ...  what is it why can i build it if i choose to ...  because i understand it ... why
cuz i invented it ...
