Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
gadgetmall
Excelent Alex . Your are an angel in a santa Suit :) Merry Christmas And a VERy Happy day Indeed ! And I hope and pray this will show What i believe to be a Wonderful Machine and the first of its kind !
Good night and Noel
Pirate88179
Alex:
Super job man, I knew you would get it figured out, I have faith in you.  I imagine the testing will take quite a while, possibly forever if Gadget is correct, ha ha.  This will be great.
Merry Christmas Alex
Groundloop
Albert and Bill,
Thanks and  Merry Christmas.
Now I can finally get some sleep. :-)
I will test the BACP setup when the Gadgetmall JT arrive. Probably in two weeks time.
Forgot to add: The pcb was designed to accept a P-Mosfet. Now, when using a power NPN
(could be almost any power NPN with pins like base, collector, emitter) then the collector
and emitter pins MUST be crossed before inserting the NPN into the board for soldering.
So one pin must have insulation plastic tubing and then the pins must be crossed.
The posted layout files has been corrected for accepting a power NPN with straight pins.
Both transistors must be mounted with insulation rubber and plastic ring onto the heat sink.
I will answer any questions later on after I have had my 10 - 12 hour sleep. :-)
Alex.
guruji
Wow Alex you're an electronic Guru  :o. Very nice and hard work to get it all in one piece.
Nice nice Happy Christmas.
Andrew
gadgetmall
@All . Its Christmastime once again . I would like to say that Alex Is really someone Special to go thru this on a whim of mine . And Bill you are right it will Literally take possible 4 months at the least . As you all can see that the Jt on the boards run full power and only draw 2-4 milliamps Maximum ! I know this reading is correct and i have video evidence of this so with a 2500 MAH battery the jt alone will run for possible 2 months just by itself charging a bcap .With a 10,000mah D cell no telling . It will take At least another month or two after that to actually see this circuit work its Miracle . And that My friends Will be a Momentous occasion  to behold the Worlds first public self running power source . Am i scared ? Yes . Because this will Interfere with the powers at large . And that includes Battery companies , petroleum , car manufactures , and imagine the first real prototype  self powered golf cart and bicycles and the list goes on . So I hope and pray that what i found out By accident will serve mankind and i don't get killed in the process .
May God be on our side  and the project succeeds with out failure .
Merry Christmas and a Happy New year to All
Albert   aka Gadget .
