Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
0 Members and 97 Guests are viewing this topic.
Groundloop
@guruji,
Thank you, and merry Christmas to you and your family.
Albert,
It will take 625 hours (26 days) of run time with a battery amperage of 2500mAh with a current
usage of 4mAh. It will take 2500 hours (104 days) of run time with a battery amperage of 10000mAh
with a current usage of 4mAh. If it takes longer than that then there is free energy.
Alex.
gadgetmall
Quote from: Groundloop on December 25, 2009, 09:15:46 PM
@guruji,
Albert,
Alex.
Hi Alex. I hope you got soem good ZZZ in ! . I was off a bit . OK I am making a short video tonight of the black box i have been running with the same battery AA 2500 mah for over one month ,more like 5 weeks . Now i cannot of coarse prove that the same battery has been running this device for that logn  but on my word it has been . This has been a series of screwups leaving the bulb feedback regenerator circuit screwed in for  a few missed days of over 8 hours at a time when i forgot to unscrew it . So this has not been consistent like your circuit will provide but it shows how all this will come together I would normally screw it in 30 minuits  every 2 days to regenerate the battery.The battery is showing 1.245 volts as of now and the bcap is over 1.9 volts . in 5 miunits it will have been in the regen process and i will film the battery voltage before and after . I already did the before :) It will show the battery at  a recharged state and the bcap will not have lost that much energy and i can set it in a corner for a few days and check it again . I'll to upload in an hour or so . This shows that even pulling 13 milliams i can run this circuit for months  ,years etc. that is where i got the 2 month thing from . Was just thinking wrong but as you will see its not a gag!
Also this will show that even an unefficiant Jt such as this one pulling 13 ma and outputting 5 ma can still run this long and keep the battery up
the one your getting will be way better than than this one
Albert
gadgetmall
well youtube is not cooperating tonight I have already had 4 upload failures  so i am calling it quits for tonight and try to upload tomorrow . Gnight
Dog tired Boss Dog tired
Gadget
Groundloop
@guruji,
Here is how I make a 1 Watt load. Take two 2,5 Volt 0,2 Ampere light bulbs
and put them in parallel. I use the top and bottom of a used up 9V Duracell
battery as support for the bulb sockets. Then I just use hot glue to keep the
two plastic parts together.
Alex.
gadgetmall
The Load is nice Alex. It lights up a 1.2 volt bulb very bright also .It can also power a 12 volt peltier module for a long time . I need to figure a way to store the heat and or cold so it will keep producing tha heat  or cold . Maybe oil ? This way it is possible to produce more than one watt continuious ! be it electrical or heat or cold ! The ideal container caould be a thermos  with a vacume bottle in it . I bet it cold stay hot all day !
Here is My cruddy videos . I was very tired and my voice was high and you can tell i was tired . Soory I am not a film producer  :) This was quick and dirty video . I'll make another few  with more time and better quality .
http://www.youtube.com/watch?v=Cw5sU_8LUEI
part 2 and 3
http://www.youtube.com/watch?v=D8T3UBwoxV0
Thanks for watching My stuff .
gadget
