Second Stage Joule Thief Circuits
Started by Pirate88179, November 21, 2009, 02:06:51 PM
0 Members and 42 Guests are viewing this topic.
gadgetmall
I can make it . I have to order the scrs and a couple of the diodes . One thing . the Charge Capacitor will of coarse charge over the unity of the Run Battery . I wound use a battery in the run circuit because this is the first place i saw OU produced .. So Assuming 1.495 volts @ 2500 ma and a charged cap just at 2.000 is enuff to bump the small loss of the battery ...thus it continues until we engage the thermal control or Engage the output to run Lights  and/or heat  to once we reach 2.6 . can this be adjustable ? or is it already ? we dont need a fully charged bcap to win the OU contest . As it stands its way to much ou  at 2,6  Ou . Anyone can see that . so this is why i ask to get the prize for the contributors and THEN improve the design later . I can take just one wire from the charged Bcap and hit the pos  if the input for a few seconds to restore the self run portion . Couldnt we just use for now a mosfet or scr controlled by a 555 timer timed to trigger the ,mosfet /scr for a few seconds or is this not possible without programming like apic or something ? Anyways give be a bit of time to gather the parts i dont have and i will put it together and see if this will work . with my original Experiment 1 using the AA battery to achieve Ou of the source then smake it with a burst to the primary with one wire only thus a self runner . and use the heat on demand . I can put a zenar on the charge so it dont over charge  ???
@Pony this is not a cap. anyone can charge a cap off of a Jt . i have charged one up to over 200 volts . But no work is done with them .this is not ou . ou is the ability to charge a high amperage power supply source . Heat demonstrates Ou in My setup along with the LIGHT . You build it / You have no idea what you are talking about because you have not built it.I have . I know what ou is . Its here . try and land 3500 amps or 107 amps continuous from your aa battery . YOU CANT!!with out this replication circuit .And Sir you Never answered My Question about your education and life experienced ?what's up with that ? Not knocking yo but you keep knocking me and you haven't even bruit on . No one has but be . Where are all the 80,000 ultracaps i sold . some here has a pile of them I cannot believe that i Gave you all a true OVER  UNITY DEVICE and you don't build it ? most don't realize that this can be scaled up to a very high voltage and ext ream amperage/joules to power anything in your house . . O well . i don;t care about it . Ist will be it . he owns the parts to do it . We have gave you all what you wanted and you continue  on and on and on knocking down what is already a fact . BUILD IT > anyways i will win this prize  and i will share it with ist jeanna mark jim bill xee2 groundloop and a few more that come to mind later . they are the contributors of My heater projects .
gadget
jeanna
Quote from: guruji on November 22, 2009, 03:10:55 PM
We're going to fly with this JT guys  ;D look at this video it's a toroid invention too to antigravity:
http://www.youtube.com/watch?v=dSHD9rJWHiE
Enjoy.
Did anybody note the iron filings in oil art piece I posted somewhere. It is just like some of those shots.
It was sort of like the rug symbols... bo a lot like them.
j
Peterae
You could use a low voltage motor driven gearbox powered by your secondary instead of an led, drive a couple of half circles as cams and flip 2 micro switches to swap over the charge and supply caps
poynt99
Quote from: gadgetmall on November 22, 2009, 03:40:35 PM
gadget
On the contrary, I have a very good handle on what I am talking about. It required about 5 minutes of study to understand how this circuit works. Then I realized with your capacitor tests, you were simply transferring charge between either a battery and capacitor, or from capacitor to capacitor.
Either case, this is not overunity, and thus far no one has shown with any reasonable evidence that it is. Make some proper measurements, and understand what this circuit is actually doing before jumping the gun with an OU prize application. The JT and its derivatives, is simply a boost converter.
I would encourage you and all here to study the suggestions given here by myself and others.
.99
Groundloop
@gadgetmall,
I did try to design the circuit to meet your requirements.
Yes, you can adjust the two pots. One for the charge dump voltage level and
one for the feed back charge dump to run battery.
>>programming like a pic or something ?
If we use too many pats then you will use up all the o/u you get. I have tried to
design the circuit to use no current at all when inactive.
The circuit may need some "tweaking" and change of resistor values to
get it to work. When (if) it works then I can update the circuit drawings and make
some pcbs for this project.
Alex.
