Joule Thief 101
0 Members and 37 Guests are viewing this topic.
picowatt
Quote from: tinman on April 01, 2016, 11:22:58 AM
Well i have found a problem here,and it involves the resistors.
I took a quick look at the video (very annoying ambient noise).  I'll look at it further when I have the time.
Keep in mind that Fourier says that a fast edge contains some very high frequencies, so consider both junction capacitance and switching time with regard to your pulsed diode lighting an LED (I only briefly scanned thru the video, and that is the gist of what I believe you were discussing).  Have you ever looked at a waveform using your scope's FFT function?
PW
tinman
Questions for all.
1-What wave form should be seen across the CVR.
2- Will the LED light?
Post an answer for q2,and a quick pic/sketch of the wave form across the CVR
Brad
tinman
Quote from: picowatt on April 01, 2016, 01:17:06 PM
I took a quick look at the video.  I'll look at it further when I have the time.
PW
Quote(very annoying ambient noise)
Not much i can do about the fan in the power supply.
But it's not on during the whole video.
Brad
Pirate88179
Quote from: tinman on April 01, 2016, 01:41:33 PM
Questions for all.
Brad
1.  A sine wave
2. Yes, it will light.
I am just taking a stab at the questions and I am not 100% certain that I am correct.
picowatt
Questions for all.
Brad
The turn off time of the 1N4007 diodes are probably more significant than their 15pF junction capacitance (and with three in series, that's even lower).  Depending on the LED (some are rather fast, others not so much) it too can have significant turn off time and junction capacitance.
If we are probing the CVR from left to right (scope ground on left side of CVR), my guess would be that during the negative portion of the waveform, there would be a somewhat corresponding negative waveform observed at the right side of the CVR.  The diodes, turned on during the negative portion of the applied waveform, would remain on briefly during the rising  positive going portion of the applied waveform and there would be a positive going spike observed at the CVR during and following that transition prior to diode turn off.
The LED would be turned off during the 97% negative portion of the applied waveform and may light briefly during the brief turn off time of the diodes during the positive portion/rising edge of the applied waveform (depending on the LED turn on time and junction capacitance).
So, in summary, a significant negative going something or other with a more narrow positive going spike.
That would be my guess...
PW
ADDED:
Also, regarding your previous video, you should keep in mind that the turn off time of a !N4007 is around 2 us (with some a bit more).  Your positive going waveform appears to be around 5us or so (hard to tell at your scope's sweep rate).
You might try a 1N4148, 1N914 or similar diode, as their turn off time is much shorter than the 4000 series.
