Joule Thief 101
0 Members and 25 Guests are viewing this topic.
QuoteNo MH-thats not a draw. Another attempt at avoiding the fact that you were once again wrong lol.
What that is,is showing you that you have no idea what you are talking about ;)
Go ahead Brad and say that until you are blue in the face.  You have been wrong so many times over the years but you always got kid gloves and many times you were spoon fed the answers so you could understand what you were observing.  At least on this thread you will get the truth from me.  Go on any other thread and say any whackadoo thing you want, I don't care.
Yes, I was unaware that there are ways to take advantage of resonance in a cylinder during combustion, and also for getting better air flow into and out of the cylinders.  I never claimed to be an expert in engines.  So what are you going to do?  Jump up and down in a victory jig?  Have your jig and eat it too.
Quote from: EMJunkie on April 07, 2016, 08:55:11 PM
Confused again MilleHehehehe - Wow are you wrong pal, then you Lie and Back Pedal to try to get yourself out of your lies!!!
You've gone downhill since I came back here, its just been too much for you old mate, hasn't it!!!
The pressure of being proven wrong so many times by others here, much smarter than you, is just too much!!!
Its obvious that your decline from your self-proclaimed pedestal is accelerating!!!
   Chris Sykes
       hyiq.org
You're a whack job.
Quote from: tinman on April 07, 2016, 09:52:39 PM
author=MileHigh link=topic=8341.msg479834#msg479834 date=1460077518]
So whats it going to be MH--Scope shot 1,or scope shot 2 for the attached schematic?
Are you going to side with TK,because he is your mate,and you dislike EMJ?
Or are you going to think for your self for once,and answer with what you think is correct.
!OR! are you not going to answer,as you have no idea your self how induction actually work's.
My guess is that you will say nothing--will not answer the question,as you just do not know,and do not want to make your self look any worse than you already do.
And where is that mate of yours-minnie,who said i need to brush up on my induction skill's ::)
Brad
You show a transformer and you are too dense and too lazy to use the dot convention.  You have been reminded of that several times before.
QuoteWhat a lot of crap. Since when dose a continuous flow of anything needed to show that work was done.
Just make your little presentation and we will see.
Why don't you try to master the difference between "dose" and "does" and also master the use of the apostrophe?
EMJunkie
Quote from: EMJunkie on April 07, 2016, 08:41:47 PM
Hey Brad,
Yes Sir, equal and opposite, but, there is a small catch here, reactive power can change the phase angle some! Which has nothing to do at all with Faradays Law or Lenz's Law.
This is Ping Pong Power, if an Ideal Inductor were considered, the power you put in, is the power you get out again. So properly interpreting your scope shots, you need to take into account the Phase angle on your Input.
To be correct and propper, I should correct my self some.
The phase angle difference, between Volts and Amps on the Input, actually is affected by Faradays Law or Lenz's Law!
Taking the concept of an Ideal Inductor, where all the Input Power (V * I * COS(ϕ)) is stored in the Magnetic Field (1/2 LI2), and then the Magnetic Field returnes all the Power again, is Electromagnetic Induction in its own right. So here I was not entirely correct in saying what I said.
In saying this, my meaning was from Source (Primary) Magnetic Field, to destination (Secondary) Magnetic Field. Which was the topic:
Quote from: TinselKoala on April 07, 2016, 07:07:29 PM
Brad, your scope shot shows the expected 90 degree phase difference as predicted by Faraday's Law: The induced (negative) EMF in the second coil is proportional to the _time rate of change_ of the inducing magnetic field from the first coil.
Which is totally WRONG, but I think I have said that about 4 or 5 times now...
As seen in the below Transformer Diagram, as stated, Input Current, to Output Current, resulting from Electromagnetic Induction, is 180 Degrees Out of Phase unless there is another source of Electromagnetic Induction that pushes the Phase Angle out.
Appologies for my bad wording here.
   Chris Sykes
       hyiq.org
