Joule Thief 101
EMJunkie
As I posted earlier on:
Quote from: EMJunkie on April 08, 2016, 09:16:42 PM
Electrical Science for Technicians
Ref: Electrical Science for Technicians: Page 198
and I quote again directly from this document:
The waveform shows the no-load primary current (IO), lagging the supply voltage (EP) by very nearly 90o, and being mainly responsible for setting up the magnetic flux (ϕ) in the core which, itself, also lags the supply voltage by practically 90o. The self-induced voltage in the primary winding (-UP) is shown in anti-phase (i.e. 180o out of phase) with the supply voltage.
I have clearly said on many ocasions, E.M.F is not Current, and it is not Magnetic Flux! Faradays Law of Electromagnetic Induction Predicts E.M.F, Not Magnetic Flux and Not Current!
Transformers, as is stated in the document I provided, do have phase relationships. Most all of these relationships are governed by Reactance of the Circuit, thus the reason we have seen phase angles that have been shown.
Ref:Transformer Phasor Diagrams come in several varietys, I have listed them below:
   Chris Sykes
       hyiq.org
EMJunkie
Thus the reason we are seeing Phase angle Changes...
A Requirement for, definately not a Prediction of, A Requirement for Faraday's Law of Electromagnetic Induction is the Angle of the Magnetic Field (ϕ) to the Conductor.
See my Videos:
   Electrical Energy 101 - Faradays Law of Induction - Part 1
   Electrical Energy 101 - Faradays Law of Induction - Part 2
   Electrical Energy 101 - Faradays Law of Induction - Part 3
I show the optimum angle of Flux Cutting is 90o. This is where the Maximum E.M.F (Coulombs of Charge)  is "Generated". At lesser angles, less E.M.F (Coulombs of Charge)  is "Generated"!
The equation to calculate this: ϕ = BA Cos(θ)
Where:
   B = The Magnetic Field (B) (Gauss)
   A = The total Cross Sectional Area
   θ = The Angle that the Flux is Perpendicular to the Plane.
See attached Image.
So TK's statement was totally Wrong:
Quote from: TinselKoala on April 07, 2016, 07:07:29 PM
Brad, your scope shot shows the expected 90 degree phase difference as predicted by Faraday's Law
Faraday's Law of Electromagnetic Induction does not Predict any of the said quantitys. At all.
It is Dependant on these quantities. Further more, the Angle or Sine that is Predicted by Faraday's Law of Electromagnetic Induction, from the addition of Heinrick Lenz's contribution, is 180 degrees out of phase, or Anti-Phase, like I have proven in many posts already.
And so, my comment:
Quote from: EMJunkie on April 08, 2016, 01:56:30 AM
Apples and Oranges ole Mate!!!
You really should have corrected yourself TK, it would have saved a ton of heart ache for you!!!
Now, PW an appology is in order! As I have now clearly shown that you are wrong on so many levels!!!
   Chris Sykes
       hyiq.org
picowatt
Quote from: EMJunkie on April 11, 2016, 01:43:24 AM
Once again you post a quote from your source that clearly states that TK was correct in his answer to Tinman when he stated that the scope capture showing the 90 degree phase difference between the primary current and the open circuit secondary voltage was the correct scope capture.
The above quote also states that the primary current is mainly responsible for the magnetic flux and that both the primary current and magnetic flux lag the primary voltage by very nearly 90 degrees, just as TK also stated in his answer to Tinman.
The above quote also refutes your answer to Tinman and clearly indicates that your answer was wrong wherein you stated that correct scope capture should have been the one showing the 180 degree phase shift.  Again, the above quote clearly  indicates that your answer to Tinman's question was wrong.
Surely you must also agree with the elegant logic in TK and Tinman's use of Faraday's law to further bolster their answers beyond the empirical when they stated that, as per Faraday's law, the induced voltage (open circuit secondary voltage) will be at its minimum when the rate of change of the magnetic flux is at its minimum.  And as your above quote further confirms, the primary current (as viewed on the scope) was an excellent proxy for measurement of magnetic flux.
Other than continuing to prove that TK was correct and that your multi-page "episode" of disrespect towards him was totally unwarranted, what exactly is your point?
PW
EMJunkie
How does it go? "Man Up"
Be a man and admit I was right all along!
   Chris Sykes
       hyiq.org
picowatt
Quote from: EMJunkie on April 11, 2016, 03:31:24 AM
   Chris Sykes
Your references clearly indicate that you were wrong.  Your answer was incorrect.
It is you that owes TK an apology.
