Joule Thief 101
EMJunkie
Quote from: picowatt on April 11, 2016, 04:47:37 AM
And does this tirade indicate that Faraday's law does indeed state that the induced voltage will be at a minimum when the rate of change of the magnetic flux is also at a minimum?
Do you know how small and insignificant a picowatt is? Apparently it is very hard to get it right... or something like that!
   Chris Sykes
       hyiq.org
EMJunkie
Wow youre really upset PW, Why?
Dont be sad, maybe you can learn something from the information I provided to you? Maybe 6 or 12 months some of it might make some sense to you... If not then TK can learn and let you in on the secrets...
Hahaha so very funny!!!
   Chris Sykes
       hyiq.org
picowatt
Quote from: EMJunkie on April 11, 2016, 04:50:01 AM
   Chris Sykes
       hyiq.org
Yes I do, and I routinely measure at levels well below that most every day.
Apparently you have real issues with admitting being wrong.
Is the correct answer to Tinman's original question 90 or 180 degrees?
EMJunkie
Quote from: picowatt on April 11, 2016, 04:56:46 AM
I would re-post my response, but I know you cant read it!
Now your Battleship has been sunk and youre clambering for your life boat, which looks sad for you old mate, will you be learning to read now? If so, let me know and I can re-post then!
   Chris Sykes
       hyiq.org
picowatt
Quote from: EMJunkie on April 11, 2016, 05:13:50 AM
   Chris Sykes
       hyiq.org
Goodness, your response need only be 180 degrees as per your original answer or 90 degrees based on the references you cite.
Perhaps you believe it to be something else altogether...
