Joule Thief 101
tinman
@ Bill
I believe this may be the one you are referring to?
From 17:00
https://www.youtube.com/watch?v=imlqEKrfS-k
If so,then yes. Ohms law still hold,as the resistance of the light bulb can be calculated as the heat in the bulb increases.
Not sure why he says that ohm's law dose not hold?.
Brad
poynt99
Part 1
Part 2
Lewin fails to see or explain the experiment for what it is, and wrongly claims that Kirchhoff's law does not hold, when in actual fact it does. He just does not show how. His lecture is very biased towards Faraday and is quite misleading in my opinion.
tinman
Quote from: poynt99 on April 22, 2016, 09:22:13 AM
Part 1
Part 2
So i take it that you know what is happening in that experiment?.
Well i do not,but i would like to know,and i would like to nut it out for myself ;)
Looking at the circuit below--is this correct to that used in the video?.
If so,i do not see how when a voltage potential of 1 volt is placed across the inductor,that the instantaneous voltage across both resistors is also not 1 volt. In fact,if there is enough supply current to maintain that 1 volt across the inductor,then the two resistors (100 & 900 ohm) should always have 1 volt across them. How he managed to get a negative value across the 100 ohm resister has me a little lost ATM :o. Even his frozen scope shot show's that he dose indeed have a negative value at the 100 ohm resistor ,and a positive value across the 900 ohm resistor.
UMmm ???
Brad
Johan_1955
His FACE at the almost end, still playing epiloog, he on his way out?
https://www.youtube.com/watch?v=6SFNW5F8K9Y
poynt99
Quote from: tinman on April 22, 2016, 10:44:43 AM
I believe I know most of what is going on there, yes.
Not quite.
First, make it an air-core coil.
Second, the coil is the "primary". The circuit including the two resistors and wire is the "secondary". So there is no electrical connection between the two. Yes, essentially a transformer with a 1-turn secondary.
This is in fact the experiment I encouraged you to perform a number of months ago when we were "discussing" the electric field.
