Joule Thief 101
0 Members and 40 Guests are viewing this topic.
tinman
MH
I am giving you a new knickname.
From now on i think we should call you 4T8 ;D
Quote from: tinman on March 08, 2016, 09:56:08 AM
I can answer the question very easily MH--you drive it as fast as it will go in the environment it is in,and measure the speed--100% accurate.
Using your speed measuring technique,we will never know the answer,as your missing one major environmental factor needed.
MH--do you know what you have missed ?.
My statement again:
QuoteThe answer is the maximum speed of the car is determined from where the maximum horsepower that can be output by the engine is in balance with all of the air friction and various other friction forces.
"All of the air friction and various other friction forces" will depend on the environment the car is being tested in.  So your whole line of "reasoning" is wrong when you allege that I am "missing the environmental factor."
QuoteGuess you missed yet another post,regarding resonant inductive coupling transformers  ::)
You were talking about a Joule Thief and not "transmitting power over 'mid-range.'"
Quote from: webby1 on March 08, 2016, 09:59:33 AM
https://en.wikipedia.org/wiki/Frequency
Since measuring is not an answer then how can anything be known about the oscillations per time unit?
In short, no frequency can be known without measuring the cycles per time unit unless it is compared to a known value from an item that has that value known,, which is measuring in its own way.
I refuse to believe that you can't understand the meaning of the question.
Quote from: ramset on March 08, 2016, 10:02:33 AM
Stop pointing away from yourself
You are ultimately saying here that Brad is clueless (and Smokey too) because of some standard which
You have set ,
That they could probably resonate hell off its hinges if given the chance ..
Doesn't matter to you.
No you need some standard beyond measurement criteria  ,some higher level of knowledge which
You hold Ransome and flaunt in grandiose self serving pleasure for all to see..
(And for months of time ...you sadist !!)
Bow your head with me....
Putz
And then explain the difference between what they do to resonate (measure)
And what you do with magnets ?
Double putz
If you are going to claim that you know about resonance then answering two simple questions about resonance should be a trivial matter.  But instead, it's a high-drama circus.  What can you infer from that?  Stop your ridiculous "enforcer" nonsense and support truth and education instead of skewed politically correct enforced ignorance.
Calling somebody's bluff is a worthwhile exercise in the search for the truth and we are trying desperately to tun lemons into lemonaid but the resistance is on full force.  How dare people actually demonstrate competence, this is a free energy forum after all?  We need more people like FatBird.  Why don't you go to GDS and call their bluff?
ramset
Most would call it hypocrisy !
and a double standard , with no value whatsoever but to place yourself at the top of some make believe pile of humanity.
creepy indeed !
you can't explain a magnet ,but that's OK because its you ..and we just measure .
Brad measures to find resonance [which he does Spot on whenever he pleases ]
but that's not OK he needs to bow and kiss your errr ring...
your quite odd in the way you set a standard and flaunt your self as some higher level of morality ...
very odd indeed
gotta go
however one personal comment
this ain't doin us any good...
please figure a way around this bump !
Thanks Grandma
