IST ULTRACAP 2.6VCD TO 120VAC CONVERTOR
Started by innovation_station, November 26, 2009, 10:52:48 PM
I'm seeing a yellow winding in the 4th picture which isn't there in the others? Can you make a circuit diagram how this setup should be hooked please.
MrMag
IST,
have you put power on this device?
I don't think you will get much out of it :(
You are taking DC converting it to AC then back to DC and through a bridge and then to a handful of windings.
I do see a couple of problems with this.
1 - the only voltage going through to your transformer to do anything is the left over ripple from the bridge rectifier.
2 - you have approx. 110VDC on an almost complete short which will blow either your rectifier or your inverter.
I think this might be a short thread.
nievesoliveras
@ist
If it is this the setup, the source will not get recharged.
Jesus
nievesoliveras
@ist
This is one possibility. I dont know if it will give dc voltage at the other side of the inverter. If it does, I dont know how much voltage.
Jesus
innovation_station
yikes..
mr mag maybe correct ...  if this is the case ... i have a core made to accomadate this ...
i dont see how this will not work is has no choise ...  put a load on the out wires and turn it on ..
no it will not run backward
the colpase it traped in the core ..  it must exit with the output..
it has no choise .. better results are achieved in a transformer keeper style unit this was simple and cheep and took me 15 min to make ..
w
the yellow is tape ... there 2 coils involved ...  1 the dc supply ... second 2 outputs ..
cadisous... is not dangrous..   all is contained in the core material ... and i see no reason steel will not work as A CHEEP SULOTION ..  IF YOU BANG IT TOO FAST IT WILL GET HOT ...
stands to reason ...  this is why i use LARGE FEROITE CORES ... 8)
you see the biggest reason people fail to comprhend how and why this works as it does ..
is because
this is a MULTI STAGE DEVICE...  ie
aa battery to jt to power can .... stage 1 ..... power can to eather this unit built for 2.6vdc input or
my cap motor wich gadget is testing concept public ...
that is stage 2  it will have 5 ultracaps.. lots of grunt ...  then it can go to the 3rd stage .....
the device showen ...
this will start the operation of the GRAND CYCLE  ...  from 1 single aa  ;)  lmao  and this cycle is already on rute ...  8) :o
