IST ULTRACAP 2.6VCD TO 120VAC CONVERTOR
Started by innovation_station, November 26, 2009, 10:52:48 PM
nievesoliveras
@ist
That was a wild guess.
It is a pity it will not work backward.
Jesus
innovation_station
Quote from: nievesoliveras on November 27, 2009, 10:52:39 AM
@ist
Jesus
YOU KNOW  better sir ..
;D ;D ;D ;D
it will not run backward as showen  ;D ;)
btw   thank you for your drawing jesus !!   your good at them ..  8)
it will work in that manner as well ...  all tho the input coil becomes the output ...  and i think it should be rewound to properly accomadate .. ac out then drecified to dc .. in a cap ..
basically a jt then ..
orignal design is .. a RECONNECT TRANSFORMER!  ;D
innovation_station
i add this this unit as showen is UN TUNED....
i aint giveing you 5 years of work ...   just like that ... lol
you must tune it..  mass to mass of copper  then start dubbleing out put mass coil ..
ie.   if i want 110vac x 4 feeds... i will want 1 pulse coil as showen black romex...  then i want 4 pick up coils tuned to the same mass of the primary...
say i yi yi  :)
giantkiller
Aside from the spelling and linguistic differences I do not see any questions dealing with the math here. So here are the parameters leading to this.
1: The steel core becomes an electromagnet which gives a bias from the DC.
2: The primary windings with ripple produce impedance.
3: The ripple is higher in frequency than 60hz
4: The DC ripple will rip across the secondary caduceus coil.
5: The secondary caduceus will create a one way scalar pulse that will follow the ring causing a pump. This action causes more impedance at the primary from the back side of the primary or the last winding of the secondary which can be considered as the top. I see super simple electrostatics happening here.
6: The secondary has a twist in it at some point. The stripe appears only on the second pass of the secondary winding.
7: The change or twist will have an effect but at this point I can't say whether additive or subtractive, and this is important!
8: The primary coil specifications should be worked out to provide how much impedance is produced. If sufficient impedance is caused by the ripple then this should be taken into effect. I see hash on top of DC.
9: Because of the circular Tesla coil design this will run with gain. Snake biting its tail.
10: I see a 1 lb device here.
11: I hope I have put the previous set of SM clues in place for all.
12: If it worked backward it would not create a 1 way pump.
13: If given the length of the 2 wires used then that would answer alot of questions or the height of the steel ring and the wall thickness. Then count then turns and add the lead length.
14: Also take note of the lead lengths.
15: The magnetic field from the DC becomes the bias field for the AC to work on.
I will get a steel ring or make one out of wire. We have everything else.
Take note: All of Don Smith's air coils are on hand carried wooden platforms except one: the large ring is on a cart. It is heavy.
http://jnaudin.free.fr/html/lmdtem.htm
http://jnaudin.free.fr/html/sclxmtr.htm
http://jnaudin.free.fr/html/rcoil.htm
@ist
Jesus
innovation_station
TY GK!
i think because the output coil is back wound it allows to grab noth and south poles on the on pulse ..
and agin when it colapses  ..
william
ps i porpously twisted the wire as gk pointed out!  to indicate the winding that is back wound ..  ;D
someone has there eyes on lol  ;)
