IST ULTRACAP 2.6VCD TO 120VAC CONVERTOR
Started by innovation_station, November 26, 2009, 10:52:48 PM
giantkiller
The tuning equates to the wire lengths being equal to 1/4, 1/2, or full wave length.
The diameter also helps to get the wire length.
The steel ring also confirms the age old 'No iron' core.
Quote from: giantkiller on November 27, 2009, 11:35:25 AM
Aside from the spelling and linguistic differences I do not see any questions dealing with the math here. So here are the parameters leading to this.
1: The steel core becomes an electromagnet which gives a bias from the DC.
2: The primary windings with ripple produce impedance.
3: The ripple is higher in frequency than 60hz
4: The DC ripple will rip across the secondary caduceus coil.
5: The secondary caduceus will create a one way scalar pulse that will follow the ring causing a pump. This action causes more impedance at the primary from the back side of the primary or the last winding of the secondary which can be considered as the top. I see super simple electrostatics happening here.
6: The secondary has a twist in it at some point. The stripe appears only on the second pass of the secondary winding.
7: The change or twist will have an effect but at this point I can't say whether additive or subtractive, and this is important!
8: The primary coil specifications should be worked out to provide how much impedance is produced. If sufficient impedance is caused by the ripple then this should be taken into effect. I see hash on top of DC.
9: Because of the circular Tesla coil design this will run with gain. Snake biting its tail.
10: I see a 1 lb device here.
11: I hope I have put the previous set of SM clues in place for all.
12: If it worked backward it would not create a 1 way pump.
13: If given the length of the 2 wires used then that would answer alot of questions or the height of the steel ring and the wall thickness. Then count then turns and add the lead length.
14: Also take note of the lead lengths.
15: The magnetic field from the DC becomes the bias field for the AC to work on.
I will get a steel ring or make one out of wire. We have everything else.
Take note: All of Don Smith's air coils are on hand carried wooden platforms except one: the large ring is on a cart. It is heavy.
http://jnaudin.free.fr/html/lmdtem.htm
http://jnaudin.free.fr/html/sclxmtr.htm
http://jnaudin.free.fr/html/rcoil.htm
innovation_station
Quote from: giantkiller on November 27, 2009, 12:43:32 PM
you can then work out the final details based on this...
same as with human charaka points ....  ;)   and i bet it keeps on going....
:D
fractal ring a bell  ;)
w
now you see how the 4 eagles ... create the zodiac...  to wich we exisist..
TESLA WAS FACONATED WITH COUNTER ROTATING FEILDS... hummmmmm  Y
as we go through the proton belt...  your verry understanding of creation FLIPS SYDE..  ;D
A CHANGE ...
http://www.youtube.com/watch?v=5jB_IdPiSy8
BTW IT AINT CALLED UNIVERSAL MUSIC GROUP... FOR NUTTIN!  ;)
THE GRAND AWAKENING!  THE GOLDEN AGE HAS MATURED!  ;)
nievesoliveras
@ist And @giantkiller
Thank you for the explanation.
Jesus
giantkiller
Sure thing.
The winding is easy so I will wrap an iron core and see what goes with the Don Smith way. I have no other use for the core anyway. The steel is a shopping trip in parallel.
forest
Hmm,I don't have small DC inverter. Do you have a schematic of such one for 9V battery ? :-)
Maybe some with one transistor,capacitor and a small self-made transformer. Something which SM used ? ;-)
Really I need one supersimple.
