Ionospheric antenna get 5 KW free !
Started by Tesla_2006, March 12, 2006, 07:16:05 AM
onthecuttingedge2005
the schumann resonance is perfect but what will you do when you are not around the Earth? all planetary bodies resonate at different frequencies. the perfect power source works anywhere.
just something I wanted you to think about.
still not a perfect energy source because when you use energy from the earth it slows down earth's rotation just a tad. at so,e point earth will lose all its spin or most of it and sit around like its sister venus.
from our good old friend wiki.
In the normal mode descriptions of Schumann resonances, the fundamental mode is a standing wave in the Earthâ€"ionosphere cavity with a wavelength equal to the circumference of the Earth. This lowest-frequency (and highest-intensity) mode of the Schumann resonance occurs at a frequency of approximately 7.86 Hz, but this frequency can vary slightly from a variety of factors, such as solar-induced perturbations to the ionosphere, which comprises the upper wall of the closed cavity.[citation needed] The higher resonance modes are spaced at approximately 6.5 Hz intervals,[citation needed] a characteristic attributed to the atmosphere's spherical geometry. The peaks exhibit a spectral width of approximately 20% on account of the damping of the respective modes in the dissipative cavity. The eighth overtone lies at approximately 59.9 Hz.
Jerry
MasterPlaster
Quote from: triffid on July 16, 2012, 12:59:30 AM
Hi everyone,I found a lot of info in English on electrical impulses in the earths atmosphere.Hopefully someone will find this useful?triffid
http://www.nap.edu/openbook.php?record_id=898&page=206
More http://www.earthinginstitute.net/commentaries/gaetan_electrical_surface.pdf
Thanks Triffid. Excellent information. I am looking for a pdf version of the book.
neptune
I have never tried this set up. Years ago , I was into Amateur Radio. One day there were thunderstorms in the area. I had a wire aerial about 20 metres long. I connected a spark plug between the aerial and earth . For about 10 minutes , I had a more or less continuous spark . If you try this circuit, adjust the gap of the spark gap to be as small as possible without touching .
gadgetmall
i am also an Amateur radio operator . If you live where i live it Lightnings alot to the ground . We get Jigawatts instead of 5kw from the atmosphere here. Might be good for powering that Flux capacitor or at the least Frying Electronics for insurance claims. .
bnglass
Hey folks, I translated a rough translation of Calculo using Google translator.  Anyone able to take a look at it and see if it makes sense?  I am not the greatest at understanding these things.  (new to this forum too, so bear with me)  Thanks,
Brian
