Ultracaps tested for excess energy
Started by PaulLowrance, November 30, 2009, 12:47:01 PM
Groundloop
MileHigh,
>>This probably applies to other members of the JT thread that want to build the PCB and make
>>measurements.
I assume you are referring to me since I'm the only one in the JT thread that "want to build the PCB"?
So what are you saying here? That I do not understand how an inductor works? Or that I do not
understand the relationship between energy, power and time? Or maybe you are questioning my
ability to make a PCB?
Groundloop.
Pirate88179
Yes Paul, bravo and well done.  This was a much needed test and I am sure there will be others.  I am inclined to think that the pulses will make a difference but, we will wait and see.  Gadget's circuit seems to work so I guess this is sort of like reverse engineering to try to determine why and how it works.
Anyway, great effort and we all appreciate it.  I know that your datalogger program will benefit many here on this forum.
@ Groundloop:
Just put MH on ignore as most of the  rest of us have.  It will save you a lot of time and trouble trying to explain things to someone that does not want to learn.  In his mind, he will always be right anyway so, why waste your time?
electricme
@ all
Thanks to Bill, I am now free of the "pest"
I barred "pest" from my PC  ;D ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, HOW?
Goto Personal Messages
Click on "Change Settings"
Click on "[Find Members]
select the person or non de plume
then save and exit normally
OH WHAT A FEELING    :DY :D I :D P :D P :D E :D E  :DE :D:D!
jim
gadgetmall
what "HE" don't understand is that the bcap =battery capacitor is not a capacitor at all, its a battery and a direct replacement for lithium ion batteries ! So 3500 amps in the battery cap and 2.5 amps in the battery / each one could be discharged in seconds ,minutes , hours , or days . NO DIFFERENCE !!the word capacitor is throwing him off ! the ONLY different thing about the two is the bcap can last longer than a battery and can be charged the same amount as it discharges. I fully understand that 3500 amps are whats available and i fully understand that the battery has 2.5 available amps . I know the volts go down on both and i know the available watts go with each one. what  ans poynt99 did not explain why an aa battery by it self cannot charge the bcap but yet it can charge the bcap thru a jt 8 times ?? It's not Magic  and the charge process is not an Ou effect but the final  product is the bcap will contain a full charge(BATTERYCAP) and the AA BATTERY Will NOT Require THE AMOUNT OF ENERGY IT WOULD NORMALLY TAKE TO GET THIS BATTERY CAP CHARGED > I am sure he is partially right if this were a normal capacitor But ITS a BATTERY capacitor SO you HAVE TO LOOK AT IT THIS WAY AN AA BATTERY CHARGING ANOTHER larger CELL BATTERY TO 2.6-27 VOLTS AND ITS NOT A GHOST CHARGE ! Someone tell me there is another way to take an AA battery and charge a 12 volt battery to full charge > ? or for that matter  an AA battery charge a  6 volt battery ? Or an AA battery charge a 2.7 volt battery , all without any appreciable loss from the source battery ? Other than the way i am doing it and attaining actually hard current from the result .SHow me your device that will do this in real time . They dont make them .Sure you can buy a boost converter  that runs off an aaa  or aa battery and charge your cell phone but the battery will be dead after you charge it . you have to put another battery in it to charge your 3.7 volt cell phone or mp3 battery up againg .they dont make one that will charge it up 8 times . I realize they do it in a few hours rather than spread the time out so it uses up the AA battery fast and i can do the same by increasing the bias and drawing 200-300 milliamps from the battery and possible charge the bcap up much faster but the battery will be dead fast and wont be able to be recover from the charged secondary but a few times .this is where the "trick" is . Do not discharge your battey so far that it cannot be recovered from the  Over  the unity of the charged battery  to back to the source again . It plain to see this effect as i built it . Math don't tell the story here even though is very smart or has very fast google capabilities . Anyway . It;s up to Me to prove this and my way will be to show it doing its thing. I am very confident it will self run thus proving Over unity exist . that is all i want  it to share this . Why cant it work dont matter at this point  and COP  should tell you when you all reproduce the thing . Its as simple as pie to make one . Alex is the real Genius devising what i call the OU controller circuit . I thank him fro the bottom of my heart and others should as well . It's all there anyone that can take a small risk to build this will not see  disappointment  but an accomplishment that far outweighs and experiment to date thus so far . Also if you can afford two bcaps Get em cause the effect is the same . you can charge one b cap up to 1.4 volts and charge the second one over the unity of the run bcap . I did this experiment over and over and over . I am thru and have convinced myself that i cannot do this with any otehr device except ultracaps . Everyone has always said on bedinis if its ou why do you put caps to cap and do away with the battery . well now its possible as these run a bedini and charge with the output of a bedini and its converted to real energy and not negative static energy .
I'm done for now . Lots of things to do today so Bye bye .
gadget
innovation_station
im not sideing with anyone on this ..
you know he does raise good points ... and perhaps ther is a reason he continually posts here .. and it may have less to do with covering up the truth than we  rerealize ..  it may be he has come to a true conculsion ..  but he is afarid to speek it ...
i know so far the answers i have arrived at are real but there may be more to it ..  i know i have solved many of teslas little riddles ... but i doubt i have solved them all ...
for the reccord .. i have only read a few of his pattends .. and in all honesty there only a few 1 must study to GRAB A HANDLE ON THIS...
as well im not sure DON SMITHS conculsion is correct!  .. back ground noise ... BULL SH@#
LOL
w
i know you all live in a noisey world .. but is that the source ? .. or is that the cause ...  to me the noise is from a squeekie bearing ... and it messed small human minds all up ...
so i will say noise is an effect ... of the weekend sclar feilds of the earth ...  so it wobbles .. makes noise .. and simple minds are crowed with junk ...
so get rid of noise ... tune to earth harmonics ... PRPOERLY ... and harvest!  its just that SIMPLE ...
LMFAO!
william
HERE IS A PICTURE TO REMIND EVERYONE ON THIS SITE WHY PICTURES ARE NO LONGER SHOWEN ON OU ....   THINK ABOUT IT ...  THINK WHY IT IS THIS WAY .. NOW ... THINK WHO DID IT ?
dont think to hard ... i did it ...
