Ultracaps tested for excess energy
Started by PaulLowrance, November 30, 2009, 12:47:01 PM
PaulLowrance
Quote from: innovation_station on December 11, 2009, 12:50:17 PM
not being rude paul in any way .. ok
but if we tuned our secondary jt wire to a HIGH SELFINDUCTANCE.. you can then remove the pot all resistors and it will scare you sir!
w
No doubt. Removing the base resistance would probably draw some real juice from the battery. You must have one heck of a transistor.  :D
innovation_station
yes it will to the PRIMARY ONLY... THAN BOUNCE IT BACK...
lol
it is a shift of current that is only borrowed ..  the shift in current causes a huge colpase .. and the second tuned wire is your resistor  et choke..
so it is verry cool ..
i can configure it tonnes of ways to do many things ..
and only the choke engery is used and it is not used at that ... simply shifted .. to the output cap along with the colpase ...
agin ... milions of ways  but
up  pops THAT 1 THING ... agin
one  thing       maybe she is ready to listen now ....  may be not ...  but guess what ... my words are the same ...
http://www.youtube.com/watch?v=zI0OcZKbk6w
so i picked up MY OLD GUITAR ... and began to MAKE IT SINGGGG
1 day ..  some day!
http://www.youtube.com/watch?v=eCPSv5bLw_c
gadgetmall
Quote from: MileHigh on December 11, 2009, 11:14:45 AM
Albert:
I have a feeling that I brought a lot of interesting issues to the table that may not have been raised before.  Cores themselves don't have a resonant frequency.  It's the coil inductances in combination with the toroid core and the transistor that determine the resonant frequency.
Paul:
What a load of crap and don't you dare call me a liar.  Anybody that reads this thread from start  to finish can decide for themselves who is telling the truth and who is lying.
You are so Orwellian that it is almost scary.  You are a junior amateur electronics guy with blinders on obscuring 75% of your vision sitting in your little Orwellian fishbowl filled with murky water.
again  NO ONE WILL AGREE WITH YOU ON THAT . a CORE RESONATES WITH THE CIRCUITRY . ONE HAS SUGGESTED TO TAP IT HUNG ON A STRING AND HEAR IT RING AND THEN TUNE THE JT TO MATCH IT . ..  o boy boy forget it know it all . no one can say sH!* hit without your counter BS.Only Experimenters know for sure bud . you dont have an experiment to show this . and you have never heard a toroid or led sing . As can the wires and transistor sing as well . no kidding .
gadgetmall
Quote from: PaulLowrance on December 11, 2009, 11:42:19 AM
This is better. After adjusting the 10Kohm pot to as far as it goes, the input is now 20.0mA, and output is 8.8mA. Since the bcap0650 voltage is about the same as the AAA, that would make this JT about 44% efficient, which is a lot better than yesterday!  ;D
Maybe if it had more resistance on the base the efficiency would increase even more.
Yes put a resistor in series with your pot and a cap across the resistor . IST dont  care about conservation of energy which is essential in my circuit  in order for the OU controller to work . I use less than 13 ma with 5 ma out . with your AAA battery i recommend lower than 13 ma . The Goal and my purpose was to make it efficient and run the longest it can without pulling the  battery down below a certain limit . My limit is 1.255 at which point i recycle the bcap energy back into the battery to bring it back to 1.3 . I also believe the negative back spike are more random when the transistor is powered below saturation and still provide a nice current to charge a bcap . Scope will prove this later on . .
PaulLowrance
In a bit I'll repeat the JT experiment using the AA 2000mAh instead of the wimpy AAA 700mAh. I sure hope it increases the UC more than 0.2 volts.
