New Device
Started by allmee, November 30, 2009, 09:26:32 PM
allmee
mr_bojangles
it might be my computer but i can't see the top half of your drawing on that link
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
overtaker
On my computer I can change the setting from 100 % to 75 % and see the rest of the image.
The tab on my computer is in the bottom right corner.
I hope this helps.
mr_bojangles
it worked when i right clicked "see background image"
nonetheless,
so you are using centripetal force to get height and then gravity to pull it back down?
and the propellers are generating electricity?
i like the idea but i wouldn't have the water do work until after its at the top, so i would put the props when the water is going back down, either in the lid or in a prop that sits right at the top of the cylinder before the water goes back in
i do like how once it gets spinning it will take less energy because the weight of the water will flywheel,
maybe give a small explanation, a step by step breakdown of what will/should occur, for i am going off my own assumptions
-WC Fields
allme, you will soon notice that the problem is not coming up with an idea but actually building and testing it.
Ted at:
http://hereticalbuilders.com/showthread.php?t=7
is working on a similar idea only is he using the pressure for making a jet instead of turning a turbine. If you want build this I advice you to post there as well as Ted is a very skilled builder who can give you some pointers.
