Counter Rotating Coaxial Cylinder HPG
Started by gravityblock, December 04, 2009, 06:48:15 AM
gravityblock
Broli,
The customized slip ring electrically connects the counter rotating discs together to increase the EMF on the discs, while the EMF of the external circuit is much less.  The discs & magnets are attached to each other.  It's very similar to the original design of this thread and you should be able to understand it even if it's still in 2D.  I'm working on a 3D view of it and this will take me some time, possibly a couple of days....but I wanted to get it out here so maybe you can modify the concept to work in case I don't have it quite right.
Edit:  I'm not sure if the brush at the rim should be connected to the left side, center, or right side of the slip ring.  I'll let you decide.
GB
Judges
SPAM,,,POST ABOVE,,,,SPAM AND ALSO DANGEROUS
J.
Judges
http://www.overunity.com/index.php?action=dlattach;topic=8409.0;attach=39786;image
Sorry to interrupt,ignore if you wish.
What if another axel,dead center of graphic.
Take a compass and draw a circle around complete HPG
Fit every corner,axel,edge with a two ball bearing with single double cup assembly between bearings(any direction rotation)
Enclose in sphere.
Figure out how to energize it,then stand back,Anyone working on a model?
Joe in Texas
