PaulLowrance
The flip-flop circuit tests out great. It's not connected to the eOrbo yet, just a manual run. It's a d-flip-flop. The starting trigger goes to the d-flip-flop clock pin, and the ending trigger goes to the d-flip-flop clear pin. That way the timing can never get out of sync. Schmitt triggers are used between the triggers and d-flip-flop. The Q pin will go to the mosfet, which will go to the coils.
Also I might use LEDs & photodiodes instead of pickup coils.
Bruce_TPU
Hello ALL,
My Steorn Magnet Motor is complete, and I am just now working on my electronics.  I can't wait to have this thing up and running so that I can begin to experiment!
Cheers,
Bruce
Omnibus
Did you read this:
QuoteWe will be placing a system in the Waterways and will allow people to bring their own test equipment (or use ours) - and you can test a system the way you see fit. Note that all tests like this will be done under the supervision of one of engineers - this is simply to prevent someone who might want to break a system apart. However no reasonable request will be refused.
Sean
Off to Dublin, everybody ...
This happens for the first time in our community, someone to invite people to do tests as they please on his machine. I'm out of words. That's exactly how people claiming OU should behave. Go Steorn. All power to you.
samedsoft
Quote from: Groundloop on January 02, 2010, 10:58:48 AM
@samedsoft,
Back electromagnetic force is what happen in any coil when you add current to a coil.
The coil try to resist the current change. An inductive kick back voltage is what you
get from a coil when you switch off the current in a coil. Don't mix those two.
As to you questions, I'm not quite sure what you are asking?
Alex.
Dear Alex,
   I meant the BEMF due to loading on the secondary side of the transformer. On a regular transformer, loading on secondary increases primary current.
   I thought your system did not increase primary current.. I was thinking orbo..
  You know when Ossie loads his orbo it does not consume much current on the primary.. But he looses rpm.
  In a similar sense, loading on orbo trafo secondary may cause a lag on primary current maybe?
  Rather than resistor using an inductor would make latency on middle transfer system. Latency would cause consuming reactive power and conversion of reactive power to active power.... as Thane's Bi-Toroid Transformer..
  Could you please post a video in this topic?
  Thanks...
Groundloop
@Bruce_TPU,
Great work. If you put your toroids flat against you rotor the you get only one
attraction point instead of two. My I recommend you put your toroids horisontal
with the toroid hole pointing upwards.
Alex.
