0 Members and 108 Guests are viewing this topic.
callanan
Quote from: k4zep on January 02, 2010, 06:34:21 PM
OK GANG,  check out:
http://www.youtube.com/watch?v=I3LUakks9U4
Actually it will run @ .900 VDC @ 12 ma.  DC pulses should be would be 130 ma but with the coil as an AC device, current drops WAY down.
Enjoy, Their ORBO will run on 1.5 VDC,.....well I proved it will run on .900 VDC, with only one coil,thery are the real thing as far as a motor goes!!!
Ben
Great work Ben!!!
Your motor will run on less energy then it takes to light a single white LED!!!
Regards,
Ossie
infringer
damn where was this sweet design when cd walkmans were the in thing?
imagine this would be a very good use for that or hell even portable DVD/BluRay units...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
PaulLowrance
OK GANG,  check out:
Ben
Congrats Ben! How many rpms at 12mA 0.9V?
Groundloop
All,
Need a little help. I have repaired my solid state Orbo and is able to run the unit
at very little input power. My digital ampere meter shows 0,00 and -0,00 alternating.
I do not trust that meter. I hooked up a analog moving Iron ampere meter. It says
zero amps. I do not trust that to be true either.
So, how can I make a accurate measurement of the input current going to the circuit?
Alex.
k4zep
Quote from: PaulLowrance on January 02, 2010, 07:34:02 PM
Paul, probably 150 rpm, didn't check.
Have found that 0.500 VDC is min rpm with crooked magnets, that it will run. About 100 RPM @ that voltage.
I have a hell of a good core/coil combination.
HEXFET Switch is reason it will run so low.  Transistor would not work here at that voltage.
Note picture below running @ .500 vdc.  Top trace when it is high, the coil is ON, as shown on the bottom trace is at the FET/coil junction.  Now will build a good motor as I know what works on the motor.  Folks, this is an AC device NOT DC.
Ben K4ZEP
