Groundloop
@interestedinou,
Well, you have to solder the wires together after you have made the windings.
I can't see any drawbacks to this. But as I said, if you want that perfect
toroid then you must go the long mile of winding a single wire. Maybe other
members have any comments on this?
Alex.
gotoluc
Quote from: Groundloop on January 05, 2010, 09:12:29 PM
@Staffman,
First, ask Gotoluc to send you a free Rosmary Anslie PCB (if he has more left).
Alex.
Hi Groundloop and all
I still have 3 boards left! after that they are gone ;D
Get your board while you can.
email me directly your full mailing address at: gotoluc@yahoo.com
Great work you're doing here as usual Alex ;)
Luc
Groundloop
FreeEnergyTruth
Quote from: plengo on January 05, 2010, 10:16:08 AM
Just sharing what John Bedini said about orbo:
Fausto.
I'm disappointed in Bedini.  He sounds a little childish here. You'd think he'd be glad someone is bringing free energy to a commercial reality. Something Bedini has never achieved.
Bruce_TPU
Quote from: Groundloop on January 05, 2010, 09:50:38 PM
@Bruce_TPU,
I can tune from a low audible frequency and up to a frequency that I can not hear
with the posted component values of the RA switch. Higher frequency gives more
output voltage. If I tune the base resistor down too much at high frequency then
I hear a click and the 555 timer blows up. My guess is that there is a feed back
of high voltages to the 555 output pin that blows the 555. Maybe negative. When
I find more time I will try adding a diode to the 555 output pin to prevent this.
But, yes, the output goes up in voltage at higher frequencies
Alex.
Hi Groundloop,
Thank you for the answers and information you have been providing.  So, I have a couple of quick thoughts...increase the frequency as high as you can design for, and second, have you tried placing ferrite or steel inside of your Generator coil to see what you might see?  Thanks!!
Cheers,
Bruce
