Groundloop
@Bruce_TPU,
There is already a Ferrite tube inside the generator coil. See my earlier posts.
I will add a switch to my setup. I can then use two ceramic capacitor
values with the switch so that the frequency can be varied over a wider range.
Groundloop.
oscar
Hi Groundloop
Quote from: Groundloop on January 05, 2010, 02:20:53 PM
...I have also learned that the generator coil must be
a high turn (thin wire) coil so that we generate a LOT of voltage with almost no
current. ......
when you wind your next generator coil, maybe you can put a centre-tap in it.
Then you may want to test this arrangement again:
Quote from: Groundloop on January 05, 2010, 03:00:55 PM
With two magnets PUSHING at each other at both ends, zero volt at output.
Did try NN and SS and zero volt in both cases.
Maybe you will get "two outputs" with the centre tapped generator coil.
measuring between each end of the generator coil and it's centre.
Just a thought.
Thanks
The transmission was a '53 (Johnny Cash)
Groundloop
@oscar,
I already have a center tap at my generator coil. So I will try it out.
Alex.
Pirate88179
Looks to me like if Steorn had anything original they would run it from supercaps or a B-cap instead of a battery.  A Bedini will run very well from supercaps or a B-cap.  I can ever run one of mine from my EER.
I agree with John Bedini on this one.
exnihiloest
Quote from: PaulLowrance on January 05, 2010, 09:48:43 AM
That is highly illogical. Science is not about waiting for people to prove things to you.
It is right but not the point. Science is people proving things to others, others verifying such things, and every body agreing one each other on facts and theory.
Besides, I have my proof that the magnetic material cooled by nearly 3°F, all of which was on video. To varying degrees this was seen numerous times in other experiments.
Science is not claiming without proof. If your assertion is not accompanied with solid evidence and all the stuff for its replication by an independant team, what you say or nothing is the same.
Magnetic cooling is not even a OU proof, it is conventional technics.
Did your experiment be replicated and confirmed? Not only the cooling but also OU?
"My" proof is lacking meaningfulness. A personnal proof is conviction or faith. A real proof is shareable.
