Bruce_TPU
Quote from: Jimboot on January 09, 2010, 08:07:08 PM
Vid is now live. Accidentally made it private last night.
Hi Jimboot,
Video looks good.  How many ohms are your toroids?  What awg magnet wire and length per toroid?  And, lastly, I could not see your trigger coil.  What size wire for it and length?  I ask because I am comparing the builds I have seen in this regard, and getting ideas for when my toroids arrive...hopefully Monday.  I am wrapping them with 26awg.
Thanks!
Bruce
plengo
Quote from: Bruce_TPU on January 09, 2010, 05:43:54 PM
... .  He works full time, paid, to disprove FE devices.  Just my 2 cent's worth, and nothing I have not told Al in private.
Not taking part in any side BUT I was wondering the same. So many videos. Either he is paid or he is retired.
Fausto.
Jimboot
Quote from: Bruce_TPU on January 09, 2010, 08:35:51 PM
Hi Jimboot,
Thanks!
Bruce
Hey Bruce, I'm still working with Ossie's original  switch circuit. I couldn't keep up with him so I decided to get the original one working first :) Switching coil is next. The toroids have around three layers of 0.5mm & 2.8 ohms
callanan
Quote from: Jimboot on January 09, 2010, 09:03:27 PM
Great work Jimboot!
Regards,
Ossie
