0 Members and 65 Guests are viewing this topic.
Airstriker
Ok time for some interesting info for the replicating guys from my side:
SOFTMAG 78 Series (78%Ni, Fe rest) (also known as Mumetal ;) - very high permeability, low saturation alloys. This family of alloys shows very high initial and maximum permeability- at low magnetizing forces, low core losses and very good magnetic shielding characteristics. There are six grades of alloys under this series, composed basically of 78% Ni-Fe-Mo and classified according to their permeability characteristics.
78A Series, 78B Series & 78C Series contain small quantities of copper in addition to molybdenum as an alloying element. They are supplied in the form of sheets, strips, cores and laminations.
78D Series & Series 78E are supplied only as tape wound cores in the heat-treated condition to gain optimum magnetic properties higher permeability and reduced losses.
Series 78F is an alloy which exhibits a rectangular hysteresis loop due to special heat treatment. It is obtained from 78D Series heats and is used in the form of cores for magnetic amplifiers, DC transformers, memories, etc.
You know what you need it for, right ?
http://www.aemcores.com.au/index.php/transformer-products/toroids/mumetal-toroids
PaulLowrance
Quote from: esaruoho on January 12, 2010, 06:05:23 PM
Steorn examine attempted replications of Orbo technology:
http://www.youtube.com/watch?v=v_MA86Czou8&feature=sub
Wow, there's a lot of helpful information in that new video for replicators!
captainpecan
Quote from: ltseung888 on January 12, 2010, 06:39:45 PM
I believe most of you still have the mind-block of the Law of Conservation of Energy.  You still think that the output energy cannot possibly be greater than the input energy as that violated the Law of Conservation of Energy.
If you think of the Orbo as leading-out (or bringing-in) electron motion energy from the surrounding, then the problem is solved.  To be more specific, magnetic energy is a form of electron motion.  When an electron orbits around the nucleus, a tiny magnetic field is produced (or the equivalent of a tiny magnet).  We can use a bit of electromagnetic energy to align such electrons.  These aligned electrons (or tiny magnets) will provide the additional energy to the system. The Tong Po Chi Lead-Out Energy Machine demonstrated to over 25,000 persons in Hong Kong can do that.  The Orbo can also do that.
Details are in the Lee-Tseung Lead-Out Energy thread on this forum.
Ummm...  Not really my question.  I am asking if he is accounting for the energy used to keep the field built up in between the start of the pulse and the end of the pulse.  Now if he is getting 10 times the amount of energy back when disconnected, then it makes up for the time energy was used to keep the field alive.  I'm just looking for a bit of clarification, as it seems he is eluding to saying he does not need the generator coils hooked up at all, and that the motor part itself keeps the batteries charged.
And no, if I had the mind block of conservation of energy, I wouldn't even be here.  The law of conservation of energy holds true, it's just misunderstood.  Scientists will take a free energy device, and say it is not possible because it violates the law.  Yet, they are fine with a windmill.  If they used the same definition of the conservation law, on a windmill as they do on a free energy device, then a windmill would also be impossible.  If you ignore the wind being a piece of the equation, it is the same thing as ignoring zero point energy that enters a system.  After all, if you ignore wind, then a windmill would be WAY OVERUNITY!  The same rules do not seem to apply to a free energy device, simply because they do not believe it is possible there is another source of energy.
captainpecan
Quote from: PaulLowrance on January 12, 2010, 06:57:23 PM
I agree.  He left out some key things that would have been nice to know though of course.  But overall, it was a pretty good explanation of how bemf is lurking around in there when the current is on 100% of the time also.
k4zep
Quote from: captainpecan on January 12, 2010, 07:31:58 PM
Hi GANG,
Just watched the demo.  Remarkable.  What you see is the perfect no back EMF/CEMF GENERATOR.  SPIN the damn thing at 20K rpm via a small motor as there is no load!, very short pulses in, then with the inductance shift at turn off of just 500us/1 ms pulses/magnet passage, larger pulses and CURRENT GAIN OUT!!!!  Damn, why didn't I see that before!!!!!!
Ben
