captainpecan
@Paul,
I'm still having a bit of trouble deciding which metglass for me to order today.  I remember seeing that you posted your order the other day on this thread, for some reason I don't see it.  Maybe the graphic didn't load for me when I scanning back to find it.  But could you tell me again exactly which ones you ordered, and then if you could give me your opinion on the exact ones I should order?  What I mean is this, if you had to build a second one to test other criteria, what would you use?  I'll order that one, and then we see both results.
Bruce_TPU
Quote from: Staffman on January 14, 2010, 12:52:19 PM
Naudin just posted another video... He shows how to cancel back EMF. Very cool!!! Sorry if this has been previously posted.
http://www.youtube.com/watch?v=veoRZh0GTkQ
Edit: I see it has been posted... sorry guys!!!
HUGE experiment by JLN labs!  I had heard Sean from Steorn mention the importance of "POSITION" of the toroidal coils, and NOW we know why!  So, to briefly recap, we now have three main specs to work with...  1.  Proper permeablity of core for needed Saturation.  2.  Magnets, paired of 1 Tesla or 10000 gauss each, one facing North and one facing South.  3.  The EXACT position on the Netral line between the two magnets for the Toroid.  ;)  Ahh...the smell of progress!
But...Hmm...it still appears that there are TWO toroid, one above the other on the Demo, and they are not positioned on the neutral line.  I wonder if JLN Labs had held the toroid with the hole facing the magnets, and tested with one magnet in front of it, if the CEMF would be nil.  This would also make sense based on the Demo rigs....hmm...
Cheers,
Bruce
lumen
@exnihiloest
Most of us already knew the inductance could only change if the saturation occured in a direction around the core.
The problem is your test does not show CEMF. The field generated by the coil is matained only in the core and the external fields mainly enter the core at a point perpendicular to the core.
Because of this, the field from the coil that is matained in the core, can never exert 100% of it's CEMF into the external field.
:-X
wings
Quote from: Bruce_TPU on January 14, 2010, 01:25:54 PM
Cheers,
Bruce
this can explain the use of micrometer not for bearing load adjustment but for rotor magnet position adjustment, acting on the spring adjustable position of the lower ball bearing ....?
Is anyone willing to go down to dublin with a maxwell ultra capacitor and testing it on the open test rig? Has anyone figured out the orientation of the magnets in the latest orbo demo?
