0 Members and 70 Guests are viewing this topic.
gravityblock
You can't compare a ferrite core with a metglass core in CEMF tests.  In most materials the core will lose it's attractiveness as the magnets approach and this is one form of CEMF and can be defeated with like poles.  The other form of CEMF is when the coil is closed prior to TDC and the magnets will induce an EMF in opposition to the current and this can be defeated with opposite poles with the proper polarity in the pulse.  The bottom line is you can only defeat one form of CEMF or the other, but you can't defeat both forms with a traditional pulse motors.
Metglas is the total opposite to all other materials.  It can defeat both forms of CEMF because the pulse can occur at TDC and become completely cloaked from the magnets almost instantly by going around 0.6T in field strength.  from 0.0 - 0.47T it doesn't lose it's attractiveness and is the reason why their magnets are around 0.47T.   between 0.5T - 0.6T it has a steep decline towards no attraction.
I now know why the rotor will rotate in the same direction when reversing the polarity pulse because all forms of CEMF has been eliminated on both the approach and departure.  Absolutely amazing.
GB
PaulLowrance
Quote from: Bruce_TPU on January 14, 2010, 04:38:47 PM
Okay, I deduce that they are using 3/8" disc magnets.  One facing is North and the other South.
Cheers,
Bruce
Awesome Bruce!  btw, if you happen to find the toroid diameter and also the separation distance between the magnets & toroid then I'd greatly appreciate it!
Bruce_TPU
Quote from: PaulLowrance on January 14, 2010, 07:27:03 PM
Hi Bruce,
Great find! That's about as close to 1T (or 0.5T for one side open faced magnet) as it gets. Do you or anyone else know how thick the Steorn magnets are?
Hi Paul,
Actually, I am not going with the 1" magnet, but rather I am going to order some 1/4" and some 1/2" magnets of the same type, they do not have 3/8" and I can't find that gauss anywhere else.  All others are in the 13000-14000 gauss range. These smaller ones are still 10800 gauss.  They look to be about 1/8", not sure about the spacing, but appears to be less than 5mm.  Hard to see.  If our magnets are too strong, greater distance would be needed.  http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=469-1002-ND  for the 1/2" size.
Quote from: PaulLowrance on January 14, 2010, 08:14:51 PM
I have been working on the toroid size and believe it to be 3/4" to 1".  I have ordered the 1" OD even though they were expensive.  I will probably use 37 turns of 20awg magnet wire and see how it looks.  I have wound so many thousands of turns on the wrong cores over the last several weeks, It will be a pleasure to wind 37 very neat winds!  LOL
Cheers,
Bruce
lumen
So what is the current best selection for the Metglas cores?
I found these at a surplus site.
http://www.surplussales.com/Inductors/FerPotC/FerPotC-6.html
Bruce_TPU
Quote from: lumen on January 14, 2010, 08:41:02 PM
The MP2510P4AH is what I ordered.  $12.00 USD each.
http://www.metglas.com/products/page5_1_6_4_1_b.asp
It is the IDENTICAL material that Paul L. and others felt would work.  the 4AH magnetic material.
